XJ ( X351 ) 2009 - 2019
Right head lamp is out
Old Oct 4, 2021 | 08:34 PM
antdavis1911's Avatar
Default Right head lamp is out
Before I buy another I want to check the fuse. Please let me know where this is located.
car XjL 2011
Old Oct 4, 2021 | 09:23 PM
Baltobernie's Avatar
Because headlamps are considered an essential safety item, regulatory agencies in most of the developed world require that this circuit be protected by self-healing relays rather than fuses. You could try putting the left headlamp bulb in the right-side assembly to validate its health. If you need a bulb, most manufacturers recommend replacing both sides, for intensity and color issues.
Old Oct 5, 2021 | 07:20 AM
Thermo's Avatar
Veteran: Navy
antdavis1911, the headlights are powered via a fuse box. The fuse box in your XJ also has a bunch of electronic relays built into it. So, you have much more than just a simple fuse box like in older cars. Both headlights are powered from this modules which has a dual fuse input. So, if you look at the fuse box inside the passenger compartment (the central junction box) and find fuses "BCM-3" and "BCM-4", those are for both headlights. They are each a 40 amp fuse.
littledan
Mar 19, 2022 07:12 PM
Golfing8tr
May 8, 2020 05:52 PM
stremsjg
Dec 18, 2018 03:59 PM
meirion1
Mar 1, 2016 04:02 PM
hiliters1975
Dec 25, 2011 08:39 AM
