XJ ( X351 ) 2009 - 2019
Rough idle
Old Feb 26, 2018 | 07:05 AM
MirzXJ's Avatar
Default Rough idle
I have searched and found really nothing like my symptoms. Occasionally when warm the car will go into a rough idle like it has camshaft upgrades. It only happens when in P but will fix itself within a couple seconds, then will start doing it again...then correct itself. Coming from my GEN 3 gm small blocks seems to be a maf issue but no codes where thrown in the XJ. Anyone here have the same issue?Picture just to show that the paint still shines
Old Feb 26, 2018 | 08:16 AM
phillyS1's Avatar
Mine had a misfire, rough idle from a bad timing tensioner. It started out very sporadic and got worse. Only happened at idle.
Old Feb 26, 2018 | 10:03 AM
MirzXJ's Avatar
Appointment made for Wed morning. Heard that was an issue with the SC motors but didn't know it affected the 5.0 NA. Did you car throw any codes?
Old Feb 26, 2018 | 05:38 PM
phillyS1's Avatar
No codes, ran perfectly except at idle
Old Mar 1, 2018 | 06:33 AM
MirzXJ's Avatar
Took it in dealership claimed that it was because of clogged air filters and needed a fuel injector cleaning. I replaced the filters myself....didn't looked clogged to me. I'll see if that helps.
Old Mar 2, 2018 | 10:19 AM
wcoy's Avatar
And did they clean the fuel injectors? I feel like I've read somewhere recently that can be an issue because of the direct injection. Mine had a bit of a rough idle sometimes, changed oil to Amsoil and it went away.
Old Mar 3, 2018 | 05:45 AM
MirzXJ's Avatar
No they did not. I just ran a treatment of Royal Purple Max fuel cleaner. Car seems to run fine now.
mystype04
Apr 11, 2019 08:46 AM
93greenconv
Jul 27, 2014 09:04 AM
xjrwithproblems
Nov 9, 2013 02:56 PM
Ipc838
Jun 26, 2012 02:50 PM
May 24, 2006 02:08 AM
