XJ ( X351 ) 2009 - 2019
Sunroof drain hole X351
Old Aug 22, 2018 | 01:35 AM
curtis505's Avatar
Default Sunroof drain hole X351
The hole is a rust going through, not a drain hole.
Hi, my friend has a rusty issue in his sunroof, the technician said X351 doesn't has a drain hole at the sunroof, is it true ? If so, how does it work during raining days ? He has a lot of rust now. See attached.
Old Aug 27, 2018 | 11:28 PM
SovietKitsch's Avatar
So I wasn't anywhere near as bad as this is, but here's my thread on the same issue a little while back. - https://www.jaguarforums.com/forum/x...agging-166389/
Old Aug 28, 2018 | 09:52 AM
XJsss's Avatar
Curtis This is the 3rd time you have asked the same question and the answer has not changed. There are only 2 drains in the sunroof at the rear.some pre 2013 XJs had rusting issues in the sunroof. Your issue is a result of sever neglect and the entire assembly needs to be replaced. We are here to aid as much as possible and re-posting the same question in hopes of getting a different response may only result in some of us ignoring you.and we do not want that.
Old Aug 28, 2018 | 05:31 PM
curtis505's Avatar
Hi, XJsss, this thread is the first thread I've asked, but no reply so I put another thread with a more specific question (where is the drain hole), then you replied to that quickly which is much appreciated and it does helped my friend to find the holes. However I don't understand why you said 3 times as there are only two threads I put. Anyway sorry for the two threads with similar questions. If necessary pls delete this one. Thanks
Old Aug 28, 2018 | 08:04 PM
XJsss's Avatar
No problem and I am sorry that we did not respond faster. don't know if you are able to connect to the site i'm adding. But if you can you can purchase a subscription that has all the workshop procedures and part numbers for many XJs.
http://alldatadiy.com
Khello
Jan 4, 2024 01:21 PM
xjfourty
Feb 27, 2018 03:10 AM
SparksInMI
Feb 20, 2018 02:21 AM
citsalp
Jan 20, 2018 07:37 AM
James Brandon Justice
Jul 21, 2013 02:45 PM
