XJ ( X351 ) 2009 - 2019
sunroof not working
Old Jul 23, 2019 | 07:05 PM
ckmarbun's Avatar
Default sunroof not working
where is the relay or fuse for 2011 jaguar xj sunroof motor? No respond from sunroof when i press the overhead switch. pls help
Old Aug 9, 2019 | 07:18 PM
mikebaker3's Avatar
On both the X308 and X350, I would recommend doing a hard reset, but with the aux battery for the X351, I don't know if one can be done.
Start with the lists of fuses in the owner manual and then see if you might have a blown fuse. My guess is that the fuse will be in the fuse box behind the rear seat arm rest. Fold down the arm rest and there is a Velcro panel to get access to those fuses. The owner manual will tell you which fuse to check.
Old Aug 9, 2019 | 11:15 PM
Nedoerr's Avatar
Just a note, my 2010 XJL doesn’t have a Velcro panel behind the armrest. For mine I have to remove the entire back seat. I could cut the leather/cloth to create a panel and add my own Velcro, but thought I’d point it out in case you also don’t have this feature.
All the best.
Old Aug 11, 2019 | 08:59 AM
clubairth1's Avatar
Community Influencer
That's interesting!
My 2014 XJR does have the Velcro panel even though I stupidly did not check the first time so I had to remove the back seat to find it!
I would consider cutting a slit for access too.
Old Aug 11, 2019 | 02:41 PM
ckmarbun's Avatar
I have fixed my Jaguar Xj 2011 sunroof .. Thank you for those who replied .
Old Aug 11, 2019 | 02:45 PM
Fraser Mitchell's Avatar
It would be nice of you could tell us how you fixed it so others with the same fault can fix their cars.
Old Aug 11, 2019 | 11:39 PM
ckmarbun's Avatar
Yes, all I did was Disconnected the Main Battery located in the trunk for 5mins and connected back..This condition must be met for this to work
Your sunroof motor must not make any noise or movement (completely dead) when you turn on your ignition key.
Old May 14, 2025 | 11:15 AM
Imrano's Avatar
I love you. I just did that and it worked!
Martyn Musch
Jul 24, 2023 04:01 PM
cleve
Jul 22, 2020 05:15 AM
Bluecortina76
Sep 15, 2017 01:52 PM
M12345678
Jul 14, 2016 12:49 PM
denisecdb
Apr 10, 2012 11:08 PM
