XJ ( X351 ) 2009 - 2019
TCM loosing connection
Old Jun 15, 2022 | 08:49 PM
Sean mccullough's Avatar
Default TCM loosing connection
Hello im new here but need some help please
I'm having an issue loosing communication from the TCM. It happened 3 weeks ago when it was raining terribly and there was standing water. It went into transmission fault mode and limp mode. I reset the computers (unhooked negative battery cable and reinstalled my tune) and it has been running well until today. It's hot no rain but it went into transmission fault and lost communication with TCM. I just rest again and it all works fine again. Just not understanding why this is happening
Thank you all for help I appriciate it
Old Jun 16, 2022 | 07:52 AM
clubairth1's Avatar
Community Influencer
Sean can you post your info?
We don't know what year and model your talking about?
You need to check for codes too. What code reader do you have?
Old Jun 16, 2022 | 09:58 AM
sorry im.driving a 2015 XJL v6 portfolio
I use an innova scanner my code is only TCM communication lost U0101
thank you for the direction and thank you for responding.. I look forward to the help
Old Jun 16, 2022 | 10:33 AM
2018XF25T's Avatar
You stated standing water. Was the car parked partially submerged in water or did you drove the car in a flooded street?
Old Jun 16, 2022 | 04:31 PM
clubairth1's Avatar
Yes can you fill us in on those details?
Maybe water is in the connections?
The U codes are network codes and it's unusual that you only have the one code? If wire problems it's common to see many U codes. Any other codes? You should at least have P1000 or P1111? Those are always present?
Also I have never seen an XJ with this code. Any chance you have an old battery?
Bludragon714
Aug 26, 2021 12:43 PM
Striker27
May 5, 2020 05:29 PM
FancyLampShade
Apr 24, 2014 03:54 PM
jjag
Mar 15, 2010 01:26 PM
