XJ ( X351 ) 2009 - 2019
Tons of circuit codes
Old Aug 19, 2025 | 03:22 PM
cw14yesss's Avatar
Default Tons of circuit codes
Hi, I have a 2013 Jaguar XJL Portfolio, it drives pretty well. Runs smooth, no hiccups. But it has a bunch of circuit codes. I don’t know if all these sensors are bad or if there is something else causing it. Here are the codes: P2400, P240c, U0447, P0238, P007d, P0062, P0162, P2405, P0061, P0181. Thank you
Old Aug 19, 2025 | 05:06 PM
Jaaag_drivah's Avatar
What is your battery open circuit voltage?
Old Aug 20, 2025 | 11:01 AM
clubairth1's Avatar
Community Influencer
Agree with the above. Do you know how old the battery is?
Post back the resting voltage after the car has sat all night.
Old Aug 22, 2025 | 04:31 AM
fossberry's Avatar
I'd start with the U0447 after checking the battery. Any fault code with a "U" indicates communication faults on the network and suggests modules aren't able to communicate as they need to. These cars are very temperamental and my XJ portfolio was no different. I went through and cleaned as many of the interconnects as I could get to on the CAN which got rid of 95% of the issues I was having. Could also be a problem with wiring or a module but start with the easier stuff first. This fault could throw up a number of the other fault codes you're seeing. It's detective work with codes. Got to sift through false triggers to find the one that's actually causing the problem. Then clear the fault codes and see what happens after a few days of driving and see what codes pop back up
Old Aug 24, 2025 | 10:14 PM
Stuart S's Avatar
First thing to do whenever you have any electrical issues is to make sure your battery is fully charged. A low battery will always cause lots of random DTCs.
Old Nov 7, 2025 | 10:00 PM
HealeyJag's Avatar
yep.
Just got thru reading about FALSE CODES.
All related to battery voltage lapses..
Especially if you have ZERO symptoms
Old Nov 8, 2025 | 10:36 AM
clubairth1's Avatar
Well another 1 poster! Hit and run so they never post back again.
Old Nov 9, 2025 | 08:36 AM
Stuart S's Avatar
@cw14yesss Are we ?
"Tagging" a Forum member (entering their screen name) causes an email to be sent to them notifying them that they've been tagged. It's a wakeup call. Will we hear back from the OP?
Stay tuned ...
Bigbuck1991
Apr 15, 2025 09:37 PM
2003JagStr
Nov 8, 2022 02:04 AM
Julia Cameron
22
Mar 1, 2021 10:20 PM
WaterDragon
Oct 11, 2012 01:55 PM
The World Tour
Jan 9, 2012 01:35 PM
