XJ ( X351 ) 2009 - 2019
Traction control light will not go out
Old Mar 29, 2025 | 04:32 PM
jaguarguy100's Avatar
Question Traction control light will not go out
My 2015 XJL has the ABS and traction control lights that will NOT go out. Are these lights controlled in series? IE- If the ABS hub needs replacing in the rear of the car, will the traction control light (And the Winter mode & performance mode) also not go out?
Old Mar 29, 2025 | 07:28 PM
Thermo's Avatar
Veteran: Navy
jaguarguy100, if you havea bad wheel speed sensor, it will light up a bunch of different stuff. This is where connecting a scanner and reading the codes associated with the ABS will give you an idea of what is wrong and why you have both of those lights. Just having those lights can be an indication of a lot of different things being wrong.
Old Mar 30, 2025 | 03:14 AM
Vasara's Avatar
Both ABS and traction control systems use input from wheel sensors. So if you lose wheel sensor input ALL systems using the data will have an error. Logic, is in it?
Old Apr 3, 2025 | 10:32 AM
Thermo, thanks for all your answers. Hey, now I have an O2 sensor fault in Bank 2, Sensor 3. Is that the one under the driver seat lowest down stream?
TN8Shooter
Feb 20, 2021 07:28 PM
coastaljag98
Sep 15, 2012 09:09 PM
djws61
Feb 18, 2012 03:49 PM
lcotelaw
Oct 10, 2011 04:45 AM
Simprof
Oct 16, 2010 05:54 PM
