Transmission Problems
Hi new member here. I just recently bought a 98 jaguar xj8
A presiding issue was coolant spraying out when i stopped and turned off the car. Replaced a hose, thermostat, and water pump with belt. Worked for about a week and it started again
A day ago i stopped at a stop sign and when i released the brake i did not move. Gave it gas and it slammed into gear. This triggered a "gearbox fault" message and threw it into a limp mode. Check engine light was on. Throws codes for gear control malfunction 2,3,5 and 1,2,3,4 as well as missing drive cycle A,B,C (P1730 and P1000)
Changing the fluid today to see what i find. Does anyone known what could've went wrong? 87k miles so i cant imagine the tranny going out so soon. New to jags but know my way around cars and transmissions
You need to ask your questions on the proper forum to get the wealth of knowledge and information on this forum https://www.jaguarforums.com/forum/xj-xj8-xjr-x308-27/
