XJ ( X351 ) 2009 - 2019
Trying to Make 2 Keys for XJL
Old Dec 10, 2025 | 09:46 AM
Durvelle27's Avatar
Right but without turning on the ignition how can SDD read the VIN?
Or do you proceed without reading the VIN?
Does that power supply have a ripple/noise rating? SDD wants <50mv rms ripple.
looks like it’s 120/50
Old Dec 10, 2025 | 01:33 PM
lotusespritse's Avatar
Originally Posted by Durvelle27
So I got my dedicated Laptop with SDD Installed, a Bigger PSU rates 82A @12V, so all im waiting on now is the Keys to get delivered and the cable
Is it exactly 12V? SDD wants more than 12V, it wants closer to 13.5V. If the voltage drops below 12.5V, SDD won't work.
Old Dec 10, 2025 | 03:21 PM
clubairth1's Avatar
Community Influencer
In the document I posted above they are specific about what IDS/SDD needs?
From that document.
Old Dec 10, 2025 | 06:07 PM
Durvelle27's Avatar
From that document.
I can always buy another one
this Power supply is rated 12V @50AMPs and the voltage can be adjusted upto 13.8V ripple around 50ms
12V 50AMP Power supply 12V 50AMP Power supply
Old Dec 12, 2025 | 11:07 AM
thierry_1500's Avatar
FWIW, there is also this:
US $369.28 | XTOOL X100 PADS Key Programmer Read/Write IMMO Chip Programming Smart Key Car Diagnostic Tool Automotive Scanner CANFD DOIP FCA
https://a.aliexpress.com/_EJXValQ
I don’t know if it does what it claims, but if I was in your situation I think I’d investigate the topic, and contact the seller to know if they guarantee compatibility for a X351, esp for what they call their « all key lost » feature.
Old Dec 12, 2025 | 07:02 PM
Durvelle27's Avatar
the claim it’s compatible
Old Dec 14, 2025 | 05:21 PM
JoshMcMadMac's Avatar
I stand corrected, I played with SDD today and it certainly seems that keys can be replaced without the ignition on. I assumed the JLR process would be similar to BMW, that they would have to program (and cut) the key based on VIN.
As has been previously stated, ensure you have a healthy battery and a substantial power supply connected. I use a Mongoose cable, as long as you get your interface connected to SDD it should be fine.
In SDD, in the Service Functions is the option to "Replace faulty/lost keys" and that should get you taken care of. I did not progress past the function screen shown below. From what I have read, they need to be new "virgin" keys. I have gotten genuine new Jaguar keys off eBay for $25-30, I prefer the quality over the cheap alternatives. That still does not get you the physical key blade, but as I said previously if you can get one then it can be duplicated by any decent locksmith for relatively cheap.
Old Dec 14, 2025 | 06:38 PM
  #28
Durvelle27's Avatar
I have a Brand New H8 AGM Battery in it plus a Backup H8 Battery. I'm still waiting to receive the key Fobs ( I ordered 2) and the Cable. Postal has been so slow. I was going to try with the power supply I have before ordering a new one.
Old Dec 15, 2025 | 08:07 AM
Jaaag_drivah's Avatar
I know you're only supposed to do this with a power supply connected, but I'm usually too lazy to connect a power supply and never have a problem. I've modified the CCF and added keys on battery power alone. It's not advisable, but it is possible. As mentioned, SDD won't let you begin unless the battery is over a certain voltage anyway.
Old Dec 15, 2025 | 09:40 AM
  #30
Durvelle27's Avatar
Luckily I have 3 Power Supplies I can use. Its just a waiting game to receive. I ordered alot of parts
2 Keys
Cable
Cabin filter engine cover
Bumper Supports
I also need a Driver Side Headlight but Haven't found one yet under $400
Old Dec 17, 2025 | 04:49 PM
  #31
Durvelle27's Avatar
Alright I ran into an issue, I got everything i needed finally and go through the lost keys option but toward the end it states I need to download some file to continue but I can't download the file. I'm using SDD V168
Old Dec 17, 2025 | 10:52 PM
  #32
Durvelle27's Avatar
After banging my head against the wall for hours I finally got it. I had to do a clean install of Windows 11 on my Laptop and installed SDD V167, After that I was able to execute the procedure and I now have 2 Functioning Smarts Keys for the Car. Was also able to start the car but got a Flashing CEL and heavy Gas smell. Car probably been sitting for months.
Old Dec 18, 2025 | 10:00 AM
  #33
Vasara's Avatar
Flashing CEL and gas smell is pointing to the leaking injectors.
Note: Lot of counterfeight injectors on the market. Search a topic on this forum.
Old Dec 19, 2025 | 05:04 PM
  #34
Durvelle27's Avatar
Letting it run I'm getting misfires on every cylinder
Codes that came through
P001D-13 Intake (A) camshaft profile control circuit/open - Bank 2
P0660-13 Intake Manifold tuning valve control - circuit open - bank 1
P0087-00 Fuel rail/system pressure - too low
P0313-00 Misfire Detected with low Fuel
Old Dec 20, 2025 | 03:20 AM
  #35
Vasara's Avatar
You might have faulty fuel pump, With insufficent pressure the injectors dont create fine spray.
Check engine cable harmness for possible lose connectors or faulty wires. Is it naturaly aspirated engine?
Old Dec 20, 2025 | 07:24 AM
  #36
Durvelle27's Avatar
Yes its a NA Engine
I'm checking over harness. I see the throttle body plug is damaged but I'm making my way through it. Is it possible having non of the interior electronics in it can cause problems as well
farm-jag
Oct 25, 2024 07:45 PM
bonanza
Jun 23, 2024 06:51 AM
Kjamo
May 18, 2022 10:56 AM
Colnago
US Western
Jul 3, 2019 05:50 PM
pragmatic
May 25, 2017 08:40 PM
