XJ ( X351 ) 2009 - 2019
Water in passanger footwell
Old Feb 23, 2025 | 11:31 AM
Harryington's Avatar
Default Water in passanger footwell
Hello, another problem only a week into ownership
After a rain storm last night I have come to find a small swimming pool in my passanger feont footwell.
I have check the scuttle in the engine bay and it looks clear
No water has come though the pollon filter.
Any ideas where the sunroof drain comes out ? Since i cant get to the drain under the glass ?
Any other thoughts welcome !
Old Feb 24, 2025 | 10:40 AM
clubairth1's Avatar
Community Influencer
Zero car information?
Hard to say?
Old Feb 24, 2025 | 03:11 PM
Strange, it's added to my bio and sig.
2010 - jaguar xj 351 v6 diesel
Have check the dash scuttle and clear thr small black drains.
And the pollon filter and housing
Old Feb 25, 2025 | 07:21 AM
clubairth1's Avatar
You have done the basics. One thing that is not common but has been reported are the moon roofs drains as you posted.
Next I would get someone in the car and then have a second person use a water hose and go over the top and watch for water inside. You can also watch for water coming out of the drains on the ground. Kind of like what happens with the AC system. Spray water on the outside of the door seams/seals as well because those rubber seals if not in place correctly have caused leaks before.
Have you seen wet door panels or A pillar covers or any dampness in the headliner?
I might even remove the passenger side door card to see if the interior is damp or shows signs of previous water.
I know the car is new to you but any chance the windshield has been replaced?
Since your in the UK (I think?) I will assume the car has seen salt and we have had several threads about rust and corrosion on the tracks where the roof glass panels move back and forth. May not be related to your water leak but open the glass all the way and then take a look from outside and check for rust and what not. Might be a good idea to lubricate the channels.
Old Mar 2, 2025 | 02:44 AM
update -
stripped down the B pillar and removed the head liner ( only front part )
after looking for the " internal drains" that are not real on a 2010,
  • i cleared the drains under the plastic covers on the out side of the windscreen - still leaking
  • after running water down the channels i found water ingress by the heated windscreen ribbon
  • took a plastic pry tools on the windscreen to find that the it has split away from the seal
Fix -
I Pried the windscreen very gently so there was a small gap and resealed with flexible silicone sealant left it 24 hours and retested, no more water.
Old Mar 2, 2025 | 07:38 AM
clubairth1's Avatar
Nice to fix something with little cost!
Glad to hear you found it.
RBaczek
Jul 11, 2022 11:11 PM
Vinnyboy
Dec 12, 2020 09:35 PM
Dino2.5Xtype02
Apr 20, 2017 10:18 PM
Angrycanuck
Aug 25, 2016 10:25 AM
dbrojr
XJ40 ( XJ81 )
Aug 12, 2011 05:06 AM
