XJ ( X351 ) 2009 - 2019
Water Pump - Clarity please?
Old Mar 12, 2016 | 12:56 PM
slojotaa's Avatar
Default Water Pump - Clarity please?
Hi all
My 2014 XJL has 15K miles on it. Took it in for annual service, and was told that I needed the water pump replaced. I read a lot on this forum regarding the pumps, and am surprised that this had to be done (and from what I hear is done every 2 years approx). This is a bad design of course.
? = Is this a design flaw that is unavoidable? I ask this as when my warranty runs out, I don't want a ticking situation that I will be replacing something like a water pump in 2 years after?
Thoughts on this?
Thanks,
Old Mar 12, 2016 | 02:02 PM
Thermo's Avatar
Veteran: Navy
Slojotaa, I have owned my car for 15K miles (car has 48K miles on it) and I am not seeing any issues with the water pump. While it does appear that the water pumps are a weak link (atleast from the factory), having it fail after 15K miles seems a bit extreme in my book.
I would say to have them fix it and then simply keep an eye on things. There will be aftermarket items out there that will have fixed the design flaw out shortly (if not out there already). This motor shares a lot of parts with the Ford 5.0L motor and I would suspect that the water pump is one of them. The Mustang/F-150 world will have an upgraded component in no time flat if this is also affecting them.
Old Mar 12, 2016 | 02:38 PM
clubairth1's Avatar
Community Influencer
First NO. No part interchanges between the Ford 5.0L and the Jaguar 5.0L. They are COMPLETELY different engines!
Yes the water pump is a known problem. But they are cheap and not difficult to replace. $90 every 2 years would be no problem.
Hopefully Jaguar or the aftermarket will release an improved version. I know my STR finally needed a water pump at 125K miles and it was different from the stock unit.
Old Mar 12, 2016 | 09:55 PM
Stuart S's Avatar
Originally Posted by slojotaa
Hi all
My 2014 XJL has 15K miles on it. Took it in for annual service, and was told that I needed the water pump replaced. I read a lot on this forum regarding the pumps, and am surprised that this had to be done ... ? = Is this a design flaw that is unavoidable? ... Thoughts on this? ...
Really? How could you be surprised if you read this thread? https://www.jaguarforums.com/forum/x...placed-132537/
Be glad that your dealer found that your water pump was leaking before it failed and your engine overheated and was damaged. Just make sure that the latest version of the water pump was installed in your car.
Old Mar 13, 2016 | 06:00 AM
slojotaa's Avatar
Ahh, thus the post, and if I had what you sent prior to, I would not have posted. I was looking for a thread such as this and am now much better informed. The power of a forum! Thanks a million, and I am lucky that this was found as was stated....thus the reason that the cost for dealer service is "quasi" justified by finds such as this. Appreciate the help!
Old Mar 13, 2016 | 02:40 PM
Stuart S's Avatar
slojotaa,
Please add your XJ to the following thread: Survey: Water Pump Replaced? Please include your model year, NA or SC, approximate mileage when replaced, and current mileage. Documenting the excessive number of water pump failures may persuade Jaguar to cover all or part of the replacement cost if out of warranty.
Stuart
Old Jul 16, 2021 | 04:09 PM
Ray Morton's Avatar
2012 XJL Smelled coolant at 51,000. Took to dealer and they told me water pump was leaking. They also told me that the cooling pipes were a two piece design and they all should be replaced. At a cost of $2,500, I had all the cooling pipes replaced. 5,000 miles later I smell the coolant again. Going back to dealer next week (nearest appointment available). Will post once I get the results. Heard some horror stories about the cooling system on several XJ's 2011-2016
Old Jul 16, 2021 | 04:24 PM
NBCat's Avatar
The water outlet pipe in the early cars was a two piece, bonded design that failed at the joint. The replacement pipe is a different design. Note that the water outlet pipe is different for the naturally-aspirated AJ133.
Both the AJ133 and AJ126 in my opinion should have their water outlet pipe and rear heater pipe linking both cylinder heads replaced together as they are each subject to failure and can cause catastrophic engine damage.
It's wise to check the coolant level weekly and any sign of coolant level changes should be investigated. If the instrument cluster displays 'Coolant Level Low' stop the engine immediately and determine the cause of coolant loss to avoid engine damage.
Old Jul 17, 2021 | 10:02 AM
clubairth1's Avatar
Make sure they check the rear water manifold as NBcat noted. It will also leak and requires the SC to come off so now you can also change the hose under the SC.
Old Sep 30, 2024 | 03:55 AM
philip23's Avatar
It’s concerning that the coolant issue reappeared so soon after the costly repairs. Given the notorious problems with cooling systems on 2011-2016 XJ models, I’d press the dealer for a more thorough inspection. Hopefully, they resolve it properly this time without further unexpected expenses. Keep us updated!
Old Oct 5, 2024 | 07:05 PM
QP7's Avatar
QP7
Wise words - I recently replaced another coolant pipe that had a small leak, but the scary part was when the tech took the old pipe off, it sheared in half at another place in that same pipe... yikes. It was totally failing in multiple places.
As for the water pump, if memory serves, on the 7th iteration of it Jaguar finally got the design correct - make sure the new one is the 7th edition!
Old Feb 4, 2025 | 08:32 AM
Matusco's Avatar
Use GEBA made in Germany not China!!!.. last one you'll ever need!!!
Old Feb 4, 2025 | 08:33 AM
Matusco's Avatar
Old Feb 4, 2025 | 08:35 AM
Matusco's Avatar
slojotaa,
Stuart
Jaguars impellers are plastic/nylon... GEBA is alloy!!!
Thermo
Feb 5, 2025 07:50 AM
drmike
Jun 26, 2022 07:21 AM
Michael?
Jul 23, 2021 11:07 AM
jbmi
Apr 16, 2021 07:11 PM
perezrp101
Apr 15, 2009 09:02 PM
