XJ ( X351 ) 2009 - 2019
Water Pump Gasket Question
Old Jun 4, 2024 | 09:25 PM
JaguarXJL15's Avatar
Default Water Pump Gasket Question
The black metal gaskets on my water pump one side has bumpy side the other bumpy side is upside down is it supposed to be like this? or are both sides supposed to be facing up? or down? or one side down other side up? I think I messed them up which side is up and which side is down? if this makes sense to anyone
Old Jun 4, 2024 | 10:06 PM
lotusespritse's Avatar
It's probably the same gasket that is flipped to fit on the other side to save the money of making 2 separate gaskets. It doesn't matter which way the bumpy side faces because either way the gasket is going to get compressed between 2 flat surfaces to make the seal.
Old Jun 12, 2024 | 11:09 AM
GreenGator71's Avatar
The gasket is the same, just flipped. Note that the piece that goes into the back of the pum that slips in, be sure you get the metal after market.
JD
StagByTriumph
Oct 8, 2020 06:34 PM
Dan R
Mar 31, 2018 10:28 AM
kccockrell
Jul 12, 2015 06:04 PM
x300drew
Jan 26, 2014 06:18 AM
bocagq45
Aug 6, 2012 07:48 AM
