XJ ( X351 ) 2009 - 2019
What do these valves tell you?
Old Apr 1, 2021 | 03:49 PM
Quietgiant's Avatar
Default What do these valves tell you?
These are from my 3.0 V6 SC Portfolio. 43k miles.
Diagnostically; What does the condition of these valves tell you?
Photos are labeled by cylinder C1, Etc.
Thanks.
Old Apr 1, 2021 | 04:19 PM
Fraser Mitchell's Avatar
You haven't told us the mileage of your car, but it looks about right for a fairly high miles car. The YouTuber "The Car Wizard" showed a car far worse than this, and how he cleaned up the valves. Does the engine use GDI (Gasoline Direct Injection) <into the cylinders> ?
Old Apr 1, 2021 | 04:51 PM
OzXFR's Avatar
It's in his sig which maybe you can't see:
x351 ‘14 XJL 3.0 V6 SC RWD 40k
Yep, definitely carbon deposits / build-up due to GDI, and I have seen that particular Car Wizard video as well.
I have twice used this gear on my 3.0 V6 F-Type, also around the same mileage as the OP's XJL:
Relatively cheap and fairly easy to use, I even figured out a way to do it on my lonesome.
Of course without major exploratory work I can't tell how well it worked if at all, all I know is the car coughed up lots of grey/black smoke through the exhaust and the insides of the exhaust tips were the blackest they had ever been for a few days until I cleaned them up.
Old Apr 1, 2021 | 09:31 PM
pdupler's Avatar
I've seen another video test of one of the "spray in" valve cleaners with before and after borescope pictures which showed almost no discernible difference. Having done the cleaning myself manually, I can tell you that stuff is pretty gummy and fairly impervious to even soaking for half an hour in carb cleaner. There's no way a dilute spray through the throttle body is going to do much. Maybe if you did it every 5,000 miles and just never let it get that bad. If you don't have the whole walnut shell media blaster setup, it takes some dental pick action followed by a generous scrubbing with a stiff bottle brush after soaking a few minutes in carb cleaner. Getting access to be able to see inside the rearmost valves is the problem, slightly mitigated in the v6 not having the back two to have to reach but you still need to be like 7 feet tall to lean over that far.
Old Apr 1, 2021 | 10:19 PM
clubairth1's Avatar
Community Influencer
Too bad your not running Meth injection. Your valves would be spotless!
Old Apr 2, 2021 | 09:08 AM
12jagmark's Avatar
I don't think I'd want to just scrub carbon off of the valve stems without vacuuming it all out and making absolutely sure that there's nothing big & hard left to go into the cylinder (smaller stuff, no problem). These valves might be saying that they'd appreciate an intake cleaning service, be it by yourself or by a professional (BG website can recommend servicers). They could also be saying something about the oil you're using, how often it's being changed, or possibly how clean your air filters are (or at least if they're extremely dirty restricting flow).
That's the thing with direct injection - no fuel flows over the intake valves, so they're at the mercy of the air intake and oil from the EGR or ... other(?).
But the shape of build-up will have at least some impact on the smooth flow of air into the combustion chamber, which can have some (slight, but noticeable if you pay attention) impact on performance. The engine wants to breath well.
Old Apr 2, 2021 | 11:16 AM
XJ8JR's Avatar
Those needs a good cleaning. I cleaned mine a year ago with 118k miles, and they didn't look too much worse than yours. I don't think the CRC spray cleaner would do anything if the deposits are already formed but it may help keep them clean after they've been scrubbed manually (or walnut blasted).
WhiteTardis
May 10, 2020 01:23 PM
Dan_NL
Mar 24, 2018 10:58 PM
lijianxi1996
Apr 23, 2017 11:36 PM
coloradocat
XE ( X760 )
20
Nov 21, 2016 11:10 PM
HouFtype
Mar 26, 2016 12:32 PM
