XJ ( X351 ) 2009 - 2019
Why these XJs depreciate so much so fast?
Old May 18, 2018 | 11:44 AM
XJ8JR's Avatar
Originally Posted by 1bad55chevy
Is there an actual difference in the design from the 2010 to the 2018 in terms of block, cylinder head, oil passages, and cooling system?? I am far from an expert but I think they are all very similar.
I can't tell you exactly what was changed, but it is fairly well known that there were upgrades made around 2013, along with the gearbox going from 6 speed to 8. I believe at least the timing chain guides were upgraded and the ECU and related sensor systems were changed from Denso to Bosch. According to Stuart at VAP, greater tune gains can be had with the later Bosch ECUs.
Old May 18, 2018 | 01:18 PM
Polyesterpig's Avatar
My 2011 N/A has been pretty solid after 95k. But I change the oil every 7500 miles. It has also overheated twice due to a crappy crossover tube design. I won’t even talk about all the brittle plastic tubes in the coolant system or the water pumps. I won’t buy a 6 cylinder engine and I prefer a non-supercharged engine. So that leaves me with 2011-2013 XJ’s.
Old May 18, 2018 | 01:30 PM
XJ8JR's Avatar
Yeah, I would not go beyond 7500 between oil changes on these engines. I'm sticking to 3000-5000 myself.
Old May 19, 2018 | 12:08 AM
dga57's Avatar
My 2011 XJL 5.0 liter Supercharged suffered a head gasket failure just before the warranty expired. Repairs were made by my dealer at no charge. Suffered another catastrophic engine failure while on a trip in March of this year and decided to trade the damned thing on a new Cadillac so I could get home. The Cadillac obviously doesn't have the panache of a Jaguar, but so far, so good. Drove 300 miles last Sunday so my wife could see her mother for Mother's Day and the Cadillac was comfortable and performed beautifully. So far, I have no regrets.
Dwayne
Old May 19, 2018 | 09:49 AM
clubairth1's Avatar
Community Influencer
Not sure of all the changes but a big one for the 5.0L V-8 was the timing chain change from 6mm to 8mm chains. Still trying to pin this down but it appears to have happened somewhere during or at the end of 2013.
So I "think" the 2014 and newer V-8's have the larger improved timing gear.
Another apparently ongoing upgrade is the water pump. This is widely known and again it looks like 2014 got a better unit BUT I did see a 5th water pump part number out there so not sure Jaguar got it right yet?
I don't consider the water pump a big deal as I DIY and it's not a hard job. The biggest threat is not getting an overheating warning until it's too late and the motor is toast!
Hopefully others can post addition information as I am VERY interested in all the details. XDave is a very informed member who has posted a huge amount details. Dave Tibbs is another one and is currently rebuilding his 5.0L V-8. If you can check out what is doing it's way beyond what most of us shade-tree guys would even consider!!
The thread is up to 9 pages now and he's not done yet.
https://www.jaguarforums.com/forum/x...177468/http://
Old May 19, 2018 | 09:55 AM
A friend at work bought a 5 series BMW the same time I purchased the XJ. She asked me if I was worried about reliability? She has her car maintained at the dealership and has every preventive thing she can have done there. She is just over 50k and out of warranty. She blew a head gasket last week. Cost her $12,000.00! She also got new tires with the $12k. She asked her service advisor if there was anything she could have done to prevent this from happening? He said no, things just happen sometimes. When it was being worked on, I suggested having the timing chain replaced, since they had to remove it. Her service advisor said it wasn’t necessary to replace it?
Old May 19, 2018 | 10:49 AM
JagGate's Avatar
If it is a chain and metal teeth it isn't necessary. If it is vinyl teeth or a belt, then they could have done this. I doubt I would put $12k into any car that is out of warranty. I also suspect she could have gone to a non dealer and gotten it done for 1/3rd the cost. The dealer is for warranty work only. Once a car is out of warranty, you are a fool to take it to the dealer.
Old May 20, 2018 | 02:35 AM
  #28
1 of 19's Avatar
Dwayne
And your otta here!.........
Just kidding
jagxkrtoofast
Aug 1, 2023 11:07 AM
Steve W
Aug 8, 2016 02:52 PM
apexhunter
Apr 15, 2015 09:12 AM
jagtuner
20
Mar 14, 2012 12:37 PM
DB6
Jun 23, 2011 10:25 AM
