XJ ( X351 ) 2009 - 2019
Wind Noise, 2012 XJ
Old Jun 24, 2016 | 02:24 PM
gregg5788's Avatar
Default Wind Noise, 2012 XJ
I have posted this before, but wondering if anyone else has problem, or had the problem and it has been corrected.
The drivers side of my car has noticeable wind noise, no such issue on passenger side. It drives me nuts, especially on a long drive.
Old Jun 24, 2016 | 03:51 PM
cicirrigi's Avatar
Hey,
I have experienced problems with wind noise on drivers side my car is a 2011 XJL. I went at Jaguar dealer to fix the issue. They have changed the upper door seal 85£ and gave me the car back. This has not fixed the issue. I went back and they've changed the bottom door seal and charged me another 85£ and this time the problem was fixed. I have visual inspected the seals before changing them and I couldn't find any issues it looked brand new but they needed replacement anyways so don't be fooled .It cost me 170£ to change the door seals and fix the problem.Check to see if this is your issue to and if it is try to change them once a time maybe only one is broken and it's not necessary to spend money on both. Hope this helps. Cheers
Old Jun 25, 2016 | 08:12 AM
gregg5788's Avatar
Default Thanks
Thanks for the information, it is interesting I had a bunch of door seals that needed replaced, they were warped and wavy looking. Once I did that the noise was worse. I haven't looked at lower door seal though...
teroks
Oct 2, 2022 04:38 PM
xjrjag
Apr 14, 2016 11:57 AM
XJS GRANDPA
Apr 13, 2016 05:29 AM
silversurfer1221
Apr 6, 2016 05:26 PM
papastoy
Apr 4, 2016 07:53 AM
