XJ ( X351 ) 2009 - 2019
Wiper Blade source
Old Dec 6, 2022 | 01:43 PM
jaguarxjl's Avatar
Default Wiper Blade source
Hi
Can someone please post links to replace wiper blades of my 2013 jag xjl. At $130 for the pair, OEM seem overly priced. Which is the best aftermarket one?
thanks
Old Dec 6, 2022 | 02:34 PM
Baltobernie's Avatar
I used Valeo from Rock Auto. Appearance identical to OE (may be the supplier?). Great performance, and they are bayonet-style, so no adaptor necessary to fit the Jaguar arm.
Use caution when replacing. This sounds condescending, but at least one member of this forum has cracked their windshield when the bare arm snapped back against the glass. If you think $130 is an expensive replacement ....
Old Dec 6, 2022 | 03:25 PM
jaguarxjl's Avatar
They have listed 19" which is I assume for the right side. All websites agree on the 19" - I assume it is on the right.
For the left one - Rock auto lists both 22" and 23". Which one should I select?
Old Dec 6, 2022 | 05:43 PM
Lightspeed's Avatar
i had one set of these which i thought i would try out, only had them fitted for 3 months but they did not perform well and were noisy on my glass which was massively annoying. Jaguar agent fitted new Bosch blades at my next B service and cannot be happier.
So these below are not so great and a waste of coin compared to Bosch.
https://www.ebay.com.au/itm/22383074...3ABFBM8Lm4nJ1h
am not sure as to why you are paying so much just for wiper blades.
Aussie site also shows part number for your ref.
https://runautoparts.com.au/bosch-ae...450mm-ap600450
450mm for passenger side, 600mm for driver for the X351
Here is my last B service info for parts, only charged $85 for original wiper blade set, that's AUD too, not USD
Regards
B.
Old Dec 7, 2022 | 09:02 AM
12jagmark's Avatar
B.
I can't imagine that the price and availability of anything in Australia would be of much help to the someone looking for price/availability of anything in Milwaukee.
Old Dec 7, 2022 | 09:20 AM
12jagmark's Avatar
+1 on Rock Auto as a source.
And:
++1 on taking extreme care on handling the wiper arm with the blade off.
My wife's windshield cracked from the edge up almost half way up when the arm slipped & smacked the windshield.
Thankfully I was able to repair that crack with a rain-ex windshield repair kit before my wife got to see it - she would've mandated a whole windshield replacement, which I have as of yet to have a seemlessly successful experience with one of those.
So now, any time I need to lift a wiper arm & take off the blade, I ALWAYS place a rolled-up towel under the wiper arm to support it up off of the windshield, assuming that while I'm holding it up, it will slip out of my hand.
The springs on the wiper arms are particularly strong, and there is nothing that comes between the end of the arm if the blade's removed.
Old Dec 7, 2022 | 09:45 AM
chrisjp's Avatar
Just measure your existing wiper blades and buy the same sizes!
Old Dec 7, 2022 | 03:07 PM
In the time it took you to type this, you could have looked it up on the Web! 22 inch.
Sean B
Dec 8, 2022 07:42 AM
zray
Mar 28, 2021 10:00 AM
johndahlheimer
Sep 17, 2020 03:10 PM
09XFSuper
Feb 23, 2013 06:38 AM
jimlombardi
Jun 1, 2011 12:41 AM
