XJ ( X351 ) 2009 - 2019
X351 Rear Sway Bar End Links
Old Jun 17, 2020 | 06:21 PM
Supercharged Jag's Avatar
Default X351 Rear Sway Bar End Links
Sorry everyone for the back to back posts (Muffler Upgrade) lol, but I got my rear end links today in the mail and they look straight forward.
I wanted to ask is it actually as straight forward as it seems? I am asking because the rear suspension is air, unlike the front. So can I just jack up the car, remove the end links and replace them? Also while the car is on jack stands, can I use a jack to jack up the hub assembly to tighten the end links to spec? The only reason I'm asking this is because like I said earlier the rear is air.
Thanks in advance!
Old Jun 17, 2020 | 08:25 PM
NvmyJag's Avatar
Thanks in advance!
Very straight forward, no need to work about the air suspension. Yes, you can just jack it up and replace the end links.
The links are exactly like the ones on the S-Type and prior XJs.
https://www.jaguarforums.com/forum/s...80/#post356251
Old Jun 17, 2020 | 09:02 PM
Well it was like it seems, pretty straight forwards. BUT the 30 minute job turned into a 2 hour nightmare.
The bottom nut came off with no problems. Held on the thread with a locking plier, and came off real easy. Now the top part was a whole new story, I put a wrench in the slot to hold the nut, and a ratchet on top (I believe a size 7 socket), it wouldn’t come off at all. The middle part of the threads were really really rusty. After 1 hour of what seemed like endless wrenching, the nut loosened some and the bottom threads were just visible enough to put PB Blaster on it (didn’t really help that much after letting it soak for a while). I kinda gave up in the middle, but after taking a 2 minute break it FINALLY came off.
I got the Mevotech over built links and they’re great quality. I didn’t even have to hold it down with a socket or anything, just had to tighten the nut down till snug.
Overall the job is really easy and straightforward, IF there is no rust. If there is I would recommend PB Blaster and leave it overnight.
Overall the **** show took me 2 hours for one side. The other side I will do tomorrow.
fidget247
Sep 30, 2021 11:20 AM
Spikepaga
Mar 14, 2020 06:53 PM
wyxtype
Apr 24, 2014 07:06 AM
scottg09
May 23, 2013 01:44 AM
juans_jag
Apr 7, 2010 05:22 PM
