XJ ( X351 ) 2009 - 2019
XJ 351 Rear sun Roof blind switch not working
Old Dec 10, 2019 | 03:42 PM
NMW's Avatar
NMW
Default XJ 351 Rear sun Roof blind switch not working
Hi
Can any body help please. The rear sun roof blind only works from the front switch roof console and not the rear switch
thank you for your time.
Mark.
Old Dec 19, 2019 | 05:24 AM
ABrice's Avatar
Originally Posted by NMW
Hi
Mark.
If the rear sun roof still works from the front switch then I’d probably investigate the rear switch. First, you should disconnect it and then reconnect it to see if it functions properly. There’s a chance that it will. If it doesn’t, I’d look on eBay for a used switch. You can find one anywhere from $40 to $80. It’s not too difficult to swap out them out. If I remember correctly, it can be carefully pulled out, then remove the connectors. Either way, my guess is that the problem is fixable spending very little money. Hope this helps.
Old Dec 19, 2019 | 12:45 PM
NMW's Avatar
NMW
Default thank you
Hi
thank you for the email i will try what you have recommended, fingers crossed -
Mark
ajax28
Feb 20, 2019 09:06 AM
djpxk8
Feb 4, 2018 10:41 AM
Colt23
Apr 29, 2017 04:32 PM
DBarry
Jun 20, 2014 07:49 AM
kntjafo
Sep 21, 2009 09:47 AM
