XJ ( X351 ) 2009 - 2019
XJ 5.0 Supercharged Brake Squeal on First Bite
Old Jul 3, 2021 | 07:47 AM
silvertonesx24's Avatar
Default XJ 5.0 Supercharged Brake Squeal on First Bite
5.0 supercharged (the larger brakes). I have tried:
New rotors
New pads (change from semi metallic to ceramic)
Lots of brake lubricant on both slide pins and backs of pads
I get an obnoxious squeal on light pressure when braking >40mph-0mph. Left front only. Increased pressure stops the squeal.
Anything else I can try before replacing the caliper?
Old Jul 3, 2021 | 11:24 AM
XJsss's Avatar
If it wasn't there before the new pads I'd change them to a different pad. I use Brembo pads and they stop well last forever and do not squeal. Oh, and they are cheep
Old Jul 4, 2021 | 09:28 AM
When I bought the car, the dealer put all new oem pads and rotors on the car. So for me, it always had a left front squeal on first bite (usually after warmed up)
I put ceramic Brembo pads on all the way around as I was so tired of the insane amount of dust from the oem semi metallic. The squeal seemed to temporarily go away, but now it is as bad as ever.
jomo
Sep 12, 2020 06:25 PM
asb
May 28, 2020 12:50 PM
afransella
Mar 26, 2019 03:43 AM
aratnam
Mar 26, 2015 11:52 AM
andersen06
Jan 16, 2010 11:36 PM
