XJ ( X351 ) 2009 - 2019
Xjl brake pad and rotor thickness
Old Aug 29, 2015 | 09:08 AM
ronald4313jm's Avatar
Default Xjl brake pad and rotor thickness
Hi. Does anyone know what the minimum thickness requirements are for brake pad and rotor replacement? Thanks.
Old Aug 31, 2015 | 07:58 AM
edobernig's Avatar
Default Look at the discs
Usually there is the minimum thickness stamped or cast into the rotor. There are also wear indicators attached to the pads. A visual inspection should tell you a lot. If the electric wear sensors activate there is no reset. They must be repalced. Because of ABS and Traction Control brakes wear faster, especially the rear. Between 20K and 30K miles would be a good time to check them.
H20boy
Dec 24, 2024 03:23 PM
Jefro
Sep 15, 2015 01:44 PM
SeanU
Sep 13, 2015 02:45 PM
1964Daimler
Sep 9, 2015 11:28 AM
JagLove86
Sep 6, 2015 10:36 PM
