XJ ( X351 ) 2009 - 2019
XJL headlight- Far right, smaller bulb
Old Jan 15, 2025 | 09:37 AM
jaguarguy100's Avatar
Question XJL headlight- Far right, smaller bulb
Guys & gals, my 2015 headlight has a default code on the headlight. The far right running light (See pic) does not light and is causing a code fault. Can it be changed out? If so, how do I get that small white cap off of it without breaking it? Thanks...
Old Jan 15, 2025 | 10:23 AM
clubairth1's Avatar
Community Influencer
Have not done that bulb but all bulbs for many years are changed from the back of the headlight. Not much room and I usually remove the headlight so I don't break expensive things but others will struggle and not remove the headlight. One other thing I do is replace all the bulbs as they do age and everything is out in the open so not much extra work.
Old Jan 16, 2025 | 07:21 AM
Yes, but how do you replace them? How does the small white cap cover come off without breaking it?
Old Jan 16, 2025 | 11:25 AM
clubairth1's Avatar
Oh sorry I thought you wanted to know if you could change the bulb from outside the headlight.
I have not changed those bulbs so can't say.
Do you have the manual? The head lights should be covered in that.
DoccyG
Jan 17, 2025 09:49 AM
karamayoko
Oct 23, 2022 08:48 AM
htrdlncn
Apr 26, 2022 08:18 PM
Jagxf2013
XF (X260)
Jun 27, 2020 01:10 PM
prodigy215
Mar 7, 2016 03:51 PM
