Headlight problem
Old Mar 20, 2024 | 09:55 AM
DoccyG's Avatar
Default Headlight problem
Hi,
I have a 1996 Jaguar Sovereign. The right outer headlight doesn't come on. The bulb is fine and so is the fuse so i don't know what to do next.
Does anyone have any ideas?
Old Mar 20, 2024 | 05:05 PM
Thermo's Avatar
Veteran: Navy
Doccy, I would be looking at relay RS47 and checking that. You may want to swap it with say relay LS54. If the problem moves to the left side, then your relay is bad. If it doesn't, then you have either a wiring issue between the body module and the headlight or the body module has failed. If you reach this point, I can give you some troubleshooting ideas. I just need to know your level of comfort using a multimeter.
Old Mar 21, 2024 | 09:14 AM
DoccyG's Avatar
Default Relay
Dear Thermo
That makes perfect sense. I haven’t got at it yet but will let you know.
DoccyG
Old Jan 16, 2025 | 07:22 AM
jaguarguy100's Avatar
Thermo, my 2015 headlight has a default code on the headlight. The far right running light (See pic) does not light and is causing a code fault. Can it be changed out? If so, how do I get that small white cap(s) off of it without breaking it? Thanks...
Old Jan 16, 2025 | 09:35 AM
Parker 7's Avatar
For a 1996 see page 107
The Main beam relay handles both left and right side so the splice between the 2
There is 2 separate relays for the dip beam as left and right
I always get the main and dip beam terminology mixed up
You can place your fingers in the right relay and feel for it clicking closed
It would be easy to have the mounting position of the large relays in the wrong mount position way back , so would have to look at the wire colors to confirm
Fuses involved
Gotta go to dialysis now
jagrepair.com/images/AutoRepairPhotos/jagxj1996.pdf
Old Jan 17, 2025 | 09:00 AM
Wow, do you have that level of detail for the relays & fuse box for a 2015 XJL?
Old Jan 17, 2025 | 09:49 AM
Parker 7's Avatar
I am certainly not up to speed on your X351 model but you may open a thread in that section to find from others in your owner group current and unexpired links to your manuals in different venues like a simple PDF or pictures ( vs. online live links for later ) available on earlier models
Scantly scanning around there was major changes in 2013 that may apply and be valid documents from there for your 2015
This is a factory link with you entering your VIN #
Jaguar iGuide Online
Seeing if I can find a pic of your wanted information , researching
Early so far but this pic for 2010
See also Workshop manual for 2015 - options? - Jaguar Forums - Jaguar Enthusiasts Forum
And also Fuse Box Diagram Jaguar XJ (X351; 2011-2015)
And this pic for 2016 if it applies
malc4d
Jan 22, 2024 08:32 AM
placer61
Nov 1, 2023 03:04 AM
Heather2812
Sep 29, 2012 07:26 AM
MikeB6.6
Jan 11, 2010 07:34 AM
