XJ ( X351 ) 2009 - 2019
XJL Transmission fault wont shift out of park
Old May 21, 2020 | 10:47 PM
Aslan's Avatar
Default XJL Transmission fault wont shift out of park
Hello,
my 2013 v6 xjl wont shift out of park and when it does it moves for few seconds and if i stop the car it wont pick up again. 90% of the time when i try to shift out of park the gears flash and transmission fault comes on dash. This is a new vehicle i just purchased from the auction. After scanning the vehicle I have two codes that I seen. not sure if this has anything to do with it but my neutral pull tab inside engine bay is pulled out about 5 inches which is a lot more than it should be and i cant get it back in.
u0402-00 / invalid data received from transmission control module
p2701-07 transmission friction element B apply time range/performance
Jagbahamas242
Mar 12, 2020 07:21 AM
gtrust1
May 20, 2018 08:09 PM
Rlover
Mar 30, 2016 10:04 PM
brisbon
Nov 1, 2012 02:59 PM
hiaig
Jan 7, 2011 08:43 PM
