The 1994 6.0 V12 would have a distributor on top of the engine, correct? That is a mechanical system that uses an amplifier (or two?). I'm not really familiar with that system, as the 6.0 of the X305 series which I own, has electronic ignition with coil packs in place of the distributor. The XJ81 6.0 and XJS 6.0 from 94-95 used a distributor ignition. Users over there can give advice on maintenance of that ignition system.
On our 6.0's (95, 96's) there are 2 crank sensors one in the front and one in the back, yours may have two crank sensors also. I spect it does. As SleekJag12 indicated above re post your question on the XJS/XJ81 forums as they have 3000 times the traffic this 305 forum has. You will have allot better chance at resolving. Do a search on them forums as chances are your issue is not unique and has already been discussed. Good luck and it's good to see you have not given up.
