XJ XJ12 ( X305 ) 1995 - 1997
Backlighting on dash switching off even with the main beam on
Old Apr 1, 2023 | 03:00 AM
N Bath's Avatar
Default Backlighting on dash switching off even with the main beam on
A bit if a strange one, I took the Daimler out for a drive in the evening for the first time in some months, and when I turned the lights on, the dash backlight came on for a few seconds, then turned off. Without it, you can’t see the speedometer at night. The behaviour was repeatable, turning the lights on means the backlight turns on, but after a few seconds, it switches off again. Any ideas on where to start with this one?
Old Apr 1, 2023 | 03:52 AM
SleekJag12's Avatar
Likely your dimmer module is failing. Will the lights stay on if you turn the little knob on the left of the column to click into bypass?
Old Apr 1, 2023 | 10:17 AM
Parker 7's Avatar
Switching to over ride will bypass the dimming resistor (and going back into the dimmer module ) and be full bright
The next step would be the grounds
If more that one section of lights beyond the instrument cluster are effected it could help narrow it down
Stereo head ?
Climate control panel ?
See page 123 or 125 for long wheel base model
www.jagrepair.com/images/AutoRepairPhotos/jagxj1996.pdf
Old Apr 1, 2023 | 12:38 PM
Parker 7's Avatar
Similar problem here
Speedometer backlight not working - Jaguar Forums - Jaguar Enthusiasts Forum
Old Apr 2, 2023 | 01:58 AM
N Bath's Avatar
Tried to do a bit of fault finding this evening, but everything was working fine. At least if it does it again I’ll know to look at the dimmer switch (which embarrassingly I didn’t even know was a thing).
Thanks for your help, I’ll post again here if it happens again, and how it gets resolved.
Old Apr 15, 2023 | 04:42 AM
N Bath's Avatar
Problem came back, adjusted the dimmer, and the backlight came back on. I’m guessing the variable resistor (I assume that’s how it works) is broken.
Thanks for the tip.
Catalyst
Sep 2, 2022 09:01 AM
Kevin richradson
Jul 26, 2021 10:51 AM
JPGR
Mar 30, 2021 01:32 AM
brinny
May 3, 2020 02:31 AM
