XJ XJ12 ( X305 ) 1995 - 1997
Battery size
Old Jan 31, 2021 | 06:04 PM
mtotrainer's Avatar
Default Battery size
What battery should i be installing in my 96 xj12? My supplier is saying a type 47 but it is less than half the size of the old battery . My engine will turn over but quite slowly and the starter motor cuts in and out as if its not getting enough power. I assumed the battery must be dieing but only marine batteries seem to be around the size of the battery im replacing. I took my type 47 out of my xj6 and it seems even weaker than the original xj12 battery .
Old Jan 31, 2021 | 07:51 PM
944play's Avatar
The group size in my car is H8 aka 49. Should be 95 amp-hours or so. HTH.
Old Feb 1, 2021 | 02:15 AM
SleekJag12's Avatar
Most USA auto parts stores show only the Group 47 for all the X300s. But that one is not really appropriate for these cars. You want the 49 or the 93. Big, powerful and heavy. 800 or 900 CCA. You can get a Napa 93 for $139.
My one year old Napa 93 must have been an old stock turd. It is down to 11.8V after only 2 days parked. Hopefully that's an anomaly. 18 months free replacement so I'll see about that. It replaced an O'Reilly Superstart that lasted for six years! Check that your new one is fresh before you carry it out.
Old Feb 1, 2021 | 07:00 PM
mtotrainer's Avatar
Default Thx guys
Thankyou to all for your help.
Old Feb 2, 2021 | 01:39 PM
mtotrainer's Avatar
Default V12 still not turning over easily
I put a new group 49 battery in my car yesterday. The first time i turned the key the engine fired up immediately. No nasty metal chanking sounds just instantly started. Every time since then it sounds like the battery is weak and the starter motor releases and re-engages the flywheel causeing a clanking sound just as the engine fires up. Im thinking weak starter motor. This car has been sitting as it only has 76000 miles on it.
Old Feb 5, 2021 | 01:05 AM
SleekJag12's Avatar
Could be the starter, but don't rush into that job until you've checked the simpler things first! Namely, the starter relay, power feed to the starter, engine ground strap, and ignition switch operation, in that order. Starter relay is the innermost of the row of 4 behind the left headlight assembly.
I don't recall exactly where the engine ground strap is located (lower left?). I'll have to look around for it next time I'm down there. I bet it needs cleaning.
Tex Jag
Mar 5, 2020 04:36 PM
Thang Nguyen
Oct 19, 2017 12:40 PM
brinny
May 29, 2017 11:45 AM
skinnypuppy_22
Dec 30, 2016 05:30 PM
NTL1991
XJ40 ( XJ81 )
May 31, 2015 08:27 AM
