Brake Hose is XJ12 specific ?!?!?
SNG Barratt lists the XJ12 as using an XJ12 only brake hose MNA5670AA with no aftermarket substitute listed… for $75.96 each! Non V12 uses MNA5680AA, and they list aftermarket as cheap as $15.63. Rock auto makes no distinction between 6.0 and non 6.0… and they have Raybestos for like $8. The hoses I just removed were Sunsong brand. Had anyone been forced to use expensive XJ12 only brake hoses?
I can't see what the difference would be. The hose fits between a hard pipe and the caliper....both of which are the same throughout the X300 series regardless of engine
The V - 12 has , if I recall from someone else in changing the piston O - rings , larger caliper pistons so may dictate the caliper as a whole is different requiring different hose fittings
It could be the front brakes are larger and the rear the same as regular
Search Genuine Braking System Parts For Jaguar Xj 1995 - 1997 (from 720125 To 812255) (x300) Classic | Jaguar Land Rover Classic Parts
