XJ XJ12 ( X305 ) 1995 - 1997
Brake Pedal Switch Failure
Old Sep 28, 2012 | 11:33 AM
al5001's Avatar
Default Brake Pedal Switch Failure
Recently I noticed that my brake light have been failing. As I read the forums someone mentioned that if the switch on the brake pedal is bad then it would not release the car from park into drive.
Yesterday I noticed the switch to release the park was intermittently failing so that means the switch on the brake pedal needs to be replaced.
the switch is $75!!!!! That is pretty expensive.
Can anyone suggest where to get it for cheaper.
Thank You
Old Oct 9, 2012 | 09:51 AM
gospeed81's Avatar
I recently checked mine out, and considered replacing it since I was having problems with tail/brake lights activating. I assumed it would be a cheap part as I've replaced a few on various Hondas and Mazdas...$75 is a bit steep.
I wonder if there isn't a way to retrofit a cheaper alternative...
Forcedair1
Sep 8, 2025 01:57 PM
flyrr100
Mar 14, 2016 06:37 AM
Jefro
Sep 15, 2015 01:44 PM
1964Daimler
Sep 9, 2015 11:28 AM
hen555
Sep 7, 2015 11:13 PM
