XJ XJ12 ( X305 ) 1995 - 1997
Interference engine or not?
Old May 17, 2020 | 10:02 PM
Cyber160's Avatar
Default Interference engine or not?
Recently i became fascinated with v12s and found that jaguars seem to be the chespest way to get one. Now i have started looking on craigslist and such and found a listing for two jaguars atm i dont. Know if they are v12s or not but on the off chance they have v12s in em. I wanna know if these engines are interference engines or not cuz one of them is missing chain, supposedly and i quote "all that is NEEDED is to put back the timing chain in & fire up she goes. House WILL NOT be available to use to attach the chain but can guaranteed that it works if assuming u did it correctly" if its an interference engine then it cant b fixed with just a chain. Obviously, but i cant find any info that says that is or isnt. Mayeb im using the wring terms when searching but when i do find a list jaguar is not on it but im just double checking on here.
Thanks for any answers in advance.
Old May 18, 2020 | 03:58 AM
1 of 19's Avatar
HE V-12 engines I believe are not interference, I am not sure about pre HE. I personally have not heard of a HE engine dropping a valve into a piston. Even a tensioner chain failure with HE's are extremely rare. Dropped valve seats seem to be far more popular. The Jag with a broken chain should be all but free, otherwise move on to the next one.
Old May 18, 2020 | 04:09 AM
Cyber160's Avatar
1 of 19
this is very reassuring thank you i wasnt gonna say no to buying em if it was an interference just one less thing to worry about now.
Old May 18, 2020 | 11:40 AM
89 Jacobra's Avatar
Active Streak: 30 Days
Just in case you are interested. I have a running V12, and the Transmission out of my 1989 XJS parts car. I'm located in NE. Arkansas. And would make somebody a deal, if you're close enough. My advice would definitely be to start with a running one. And not someone else's headache. I've had and bought hundreds of projects over the years, and it's always easier if it ran, before I got it.
Jack
Old May 18, 2020 | 12:19 PM
Cyber160's Avatar
89 Jacobra I gotta talk to my buddy and see about if these ones fall through or not. plus tbh youre far away im in Wisconsin. But the offer is greatly apreciated
Old May 18, 2020 | 11:00 PM
1 of 19's Avatar
I spect you are looking at the one on craigslist for $900.00 ish. The price is right!
Old May 18, 2020 | 11:38 PM
Jagsandmgs's Avatar
Is $900 cheap enough? Mine was $900 and all it needed was a fuel pump. If it was so simple to throw a timing chain on it, the owner would’ve done that. The tensioner alone which always has to be replaced if the timing chain is disturbed is $350. You have to borrow a special jig from JCNA to set the chain. Installing and removing the timing chain cover is a giant pain in the *** also. Getting to the front of the engine is a giant pain in the ***. I haven’t seen the craigslist ad but this car sounds like scrap! Pay scrap prices, 250 bucks, Max!
Old May 19, 2020 | 01:11 AM
89 Jacobra's Avatar
If it's any help, I have a son in Illinois just south of Chicago, and I could easily bring it there, if that would help?
Jack
Old May 19, 2020 | 07:10 AM
1 of 19's Avatar
Everything about a Jaguar V-12 is a giant pain in the ***. That's the allure. When you get it dialed in it's something special to drive, not a engine for the masses.
Old Oct 5, 2020 | 11:03 PM
wrightbenz's Avatar
Well maybe not everything is a pita 😂 the radiator cap is pretty accessible. But there are two kits to confuse things.
Andreas Schmieg
May 8, 2021 06:16 PM
JensenHealey
Dec 23, 2018 04:16 AM
Eddie602
May 20, 2017 11:22 AM
DAN L
Apr 24, 2015 12:13 AM
ronski
Feb 14, 2013 04:05 AM
