XJ XJ12 ( X305 ) 1995 - 1997
Proper tire size XJ12
Old Sep 1, 2019 | 03:58 PM
Doug's Avatar
I would go thru the effort to keep the 3.58, personally.
Your suspension swap idea sounds good to me !
Old Sep 1, 2019 | 09:47 PM
Lady Penelope's Avatar
Originally Posted by Robert Laughton
I see that the XJ12's came with 3.58 diffs, and the XJR6 3.27.
I wonder if it's worth swapping the diffs so I can keep the 3.58, if changing the IRS complete from XJR6.
I'm guessing it is worth swapping, but that's more work.
Rob
The 3.27 was so there would only be 2 shifting points between 0 - 60 mph advertising times vs. 3 shifting points with the 3.58
it does make for better fuel mileage but I don't know about off the line performance difference
If you do change the pinion gear it would give you the chance to change the differential output bearings to stay ahead of this troublesome bearing
4.09 is a gear to flirt with if you can find one but a Dana 44 set is a option , the 44 may not be correct
https://parts.jaguarlandroverclassic.../brand/jaguar/
Old Sep 2, 2019 | 12:55 AM
Oliver ,
The 4.09 I believe is used on the 3.2 liter version of the same 4.0 liter block to make up for it found on your trips to England
Whether it's metallurgical strength rated is another question
Dana option ?
Old Sep 2, 2019 | 01:04 AM
olivermarks's Avatar
Originally Posted by Lady Penelope
Oliver ,
The 4.09 I believe is used on the 3.2 liter version to make up for it found on your trips to England
Thanks for this, my car feels very strong and I don't have any great urge to get it moving faster with a lower gear ration. I may use the engine in a 76 xjc ultimately with a getrag box but for now I'm finding I'm enjoying driving the xj12 as is.
The 'troublesome diff output bearing' probably needs some attention sooner rather than later based on what I've been reading here though...
I found a rear tire had severe inside edge wear last week, was wondering if that had been caused by a rear suspension/drivetrain issue or whether the PO had hidden it back there as the car currently is is keen to turn left due to front end issues
Old Sep 2, 2019 | 08:21 AM
Robert Laughton's Avatar
Now you have me lusting for a 4.09 diff.
But, I doubt there's one around. As LP says, they were UK only I believe. Maybe Coventry West has one.
Years ago I found a S1 XJ 2.8 import, and pulled the 4.09 for my car. It made a big difference. It would actually spin the tires. I had a T700 trans, so it still rev'd okay on the highway.
It's been said often on these forums that a diff swap is the cheapest way to get more acceleration. I also have a S3 VDP with 3.31 and the difference is quite noticable. I know DD has done the same. I have a 3.58 from an XJS waiting for a project.
Best to all.....
Rob
Quartzboy
Nov 3, 2017 08:13 AM
jagtoes
May 5, 2015 09:10 AM
joolz
Nov 17, 2013 12:22 PM
Royston
May 15, 2013 06:23 AM
RomanEmpire
Jul 24, 2012 07:54 AM
