XJ XJ12 ( X305 ) 1995 - 1997
Throttle body diameter
Old Feb 27, 2021 | 04:49 PM
CrankmasterII's Avatar
Default Throttle body diameter
Hi
are the throttle bodies any different from the 6.0 vs the 5.3 v12?
thanks in advance
Old Nov 23, 2021 | 10:25 AM
octabero11's Avatar
As far as tuning a large throttle body goes, an alpha-n tune will have weird afr trends and be difficult to make drivability smooth. It will feel like an on/off switch. A MAP based tune will have a very small pressure window that is controllable by the throttle blade, every thing else will be the max pressure at that rpm. That pressure is dictated by the plenum volume. You want your throttle body to have good Showbox jiofi.local.html tplinklogin control over plenum pressure, which is load in a MAP based tune.
Old Nov 25, 2021 | 02:07 AM
SleekJag12's Avatar
^^ SPAM ^^ Ignore.
warrjon
Apr 3, 2026 03:45 AM
vincent661983
Aug 19, 2020 12:26 PM
Crandell
Mar 21, 2019 11:44 PM
fredd60
Mar 10, 2019 09:01 PM
