XJ XJ12 ( X305 ) 1995 - 1997
Water Pump Removal
Old Nov 12, 2023 | 01:05 AM
N Bath's Avatar
Default Water Pump Removal
Has anyone replaced their water pump?
Mine is leaking, although I can’t tell exactly where from. I think it also leaked onto my alternator, which is on the blink.
I can’t find any instructions in the service manual.
Old Nov 13, 2023 | 08:29 PM
Parker 7's Avatar
Water pumps usually have a weep hole on the shaft extension on the bottom between the pully and the pump body
Looking for a Doc on the X305
Old Nov 13, 2023 | 08:43 PM
Parker 7's Avatar
Nothing yet but see section 4 . 2 of the file below for the V - 12
Old Nov 13, 2023 | 08:55 PM
Parker 7's Avatar
Water pump / cooling system bolt torque chart in the biggening of this doc
File Type: pdf
Old Nov 14, 2023 | 02:32 PM
Jagsandmgs's Avatar
Done this a few times. I can only remember the first step… break a water pump bolt off in the block.
Old Mar 29, 2024 | 10:04 PM
olivermarks's Avatar
see my wrecking yard rarities post for a picture of the water pump with everything out in front of it (radiator etc)
Here's same picture with bolt holes circled in red
The routine is
remove fan and fan clutch (4 bolts on water pump studs through fan), shroud
remove water pump belt
loosen smog pump belt (sits on right as you face engine)
get a piece of card with appropriate number of holes in to store water pump bolts in correct order as they come out (they are different sizes)
May need to undo/loosen the two smog pump bolts into side of block in order to get the two bolts that go through the water pump and into the block out
use a very large socket philips head on a breaker bar to get the one philips head bolt to the immediate left of the water pump pulley
remove hoses, outer part of pump )3 bolts)
carefully encourage water pump to part company with block DO NOT FORCE you don''t want to bend it
find you've missed some bolts
remove
Not easy to find new water pumps you may have to get yours rebuilt/ resealed and new bearing
Thermo
Feb 5, 2025 07:50 AM
drmike
Jun 26, 2022 07:21 AM
Michael?
Jul 23, 2021 11:07 AM
roger.neill
Dec 22, 2013 08:39 AM
perezrp101
Apr 15, 2009 09:02 PM
