XJ XJ12 ( X305 ) 1995 - 1997
Where does this go?
Old Dec 15, 2023 | 07:25 AM
Olav's Avatar
Default Where does this go?
Almost finished the 10 month job of changing the startermotor core, changing the rh catalytic converter, cleaning the alternator inside out, changing the power steering pump seals, changing the power steering hoses reservoir side, changing the sparkplugs and the condenser.
Although I labeled every single nut and bolt I am left with this little earth cable. I really don’t know where this should go.
Anyone any ideas?
Olav
Old Dec 15, 2023 | 09:57 PM
watto700's Avatar
G’day Olav,
Did you have the bonnet/hood off your car? That cable looks like the earthing cable between the car body and the bonnet/hood that goes near the LHS hinge.
Cheers,
Jeff.
Old Dec 15, 2023 | 11:35 PM
Parker 7's Avatar
Make sure you have one attached to a ECU mount bolt ( case ground )
Old Dec 16, 2023 | 11:08 AM
Olav's Avatar
Originally Posted by watto700
G’day Olav,
Cheers,
Jeff.
Yes I have the bonnet off. Will see if I can trace the bolts where it is attached.
Thanks.
Old Dec 16, 2023 | 12:29 PM
Olav's Avatar
Found an old photo and there it is.
Old Dec 16, 2023 | 09:52 PM
watto700's Avatar
Well done Olav!
I was looking through my pix as well but you beat me too it.
Cheers,
Jeff.
Old Dec 16, 2023 | 10:31 PM
Jagsandmgs's Avatar
Kinda odd. How is that necessary?
Old Dec 17, 2023 | 04:01 AM
watto700's Avatar
Apparently this little cable earths out and discharges any static electricity buildup on the bonnet which could interfere with the car’s electronics.
There is a post which explains it in detail and if I can find it I’ll re-post it.
Cheers,
Jeff.
Old Jan 3, 2024 | 12:56 AM
watto700's Avatar
G'day Gents,
Here is the info on the bonnet earthing strap.
Cheers,
Jeff.
File Type: docx
bjarnetv
May 18, 2023 08:46 PM
olivermarks
XJ XJ12 ( X305 )
Apr 4, 2022 08:32 AM
GaryBHigbee
Apr 5, 2021 10:32 AM
kenatofc
Jan 18, 2015 10:07 PM
Don S-Type
Jun 30, 2013 03:39 PM
