Lost all power steering
Old May 18, 2023 | 07:33 AM
bjarnetv's Avatar
Default Lost all power steering
I need some help diagnosing my power steering, as it suddenly went away completely as i was out driving!
my power steering pump is recently rebuilt with new seals and after opening it up again i could see nothing wrong with it.
I have brand new hoses installed, and i tried loosening them just to see if i had fluid flow from the pump with the engine running and it does appear so.
There is no change in RPM when turning the steering wheel, and unplugging the power steering control module changes nothing - it does feel quite hot to the touch though...
also tried unplugging and cleaning the plug on the steering rack, but that also did nothing.
Any suggestions what to check next?
Old May 18, 2023 | 10:27 AM
Parker 7's Avatar
Electrically there is a variable vehicle speed module on fwd of the left front door hinge
It varies between 9 and 12 volts to the servo on the steering rack
There should be a fuse
You can put a meter on the module sockets and see if the servo is failed but I would think the system should be fail safe and keep you steering
I'll be out for the rest of the day
Old May 18, 2023 | 10:33 AM
bjarnetv's Avatar
Fuse looked good.
how do you measure the voltage on the module - just unplug it and stick the voltmeter into the plug? if so, do you have a pinout so i know where to stick them?
and yeah, you would think there would be some sort of failsafe to keep at least some level of power steering, but who knows - i tried a fault code read as well, but nothing showed up, even after disconnecting the module.
Old May 18, 2023 | 08:46 PM
Parker 7's Avatar
Red
and Slate wires , these will be DC voltage and car still 2 to 5 should read 7 volts on paper
The module needs to stay in to be powered
Unplugging the module and reading the servo you should not see infinite resistance.
See page 16 section 7 of the ZF rack repair / service manual / 7.5 ohms
File below
File Type: pdf
sigard
UK & Eire
Feb 12, 2024 08:12 AM
stuart57
Jan 26, 2022 02:45 AM
Jacob67
Apr 20, 2019 06:17 PM
sunchip
Jan 28, 2015 08:21 AM
jhxj6
Mar 22, 2010 08:25 PM
