XJ XJ12 ( X305 ) 1995 - 1997
Wrecking yard rarities
Old Mar 31, 2024 | 04:04 AM
watto700's Avatar
G’day Jags,
I have replaced my radiator from above and without removing the bonnet/hood. The empty radiator is not that heavy.
Remove the fan shroud and the radiator fan first and you’ll have plenty of room. The condenser is not an issue.
I repaired a small leak in a radiator once with a blob of JB weld and it lasted for years until I replaced that radiator when the plastic hose spigots started to disintegrate.
Cheers,
Jeff.
Old Apr 3, 2024 | 01:54 AM
olivermarks's Avatar
While we're on radiator discussions anyone know if a 6.0 V12 XJ40 has the same radiator as the x305? There's one in a yard near me, it seems to be raining 6.0 parts around here!
Old Apr 3, 2024 | 05:33 PM
watto700's Avatar
G'day Oliver,
They both look very similar on here https://parts.jaguarlandroverclassic...-jaguar-parts/ and the only difference in the relative part numbers is the suffix. Maybe a late model XJ40 radiator is suitable.
Cheers,
Jeff.
Old Apr 3, 2024 | 10:14 PM
Cheers Jeff, I'm heading over to take a look at it Friday
Old Apr 4, 2024 | 10:01 PM
Parker 7's Avatar
Check for the 3 wire temp switch on the lower aft left and grab the switch also
The radiator will need to have the hole for it
Old Apr 4, 2024 | 11:14 PM
Parker 7's Avatar
The drain valve sticking down must be on the right side at least for the inline 6 bottom chassis crossmember / pan
Old Apr 6, 2024 | 11:08 PM
Got it, in very good condition, appears to be the same as the x305. I hadn't seen an xj40 v12 before. Car was in good shape but seized.
Old Apr 7, 2024 | 01:41 AM
  #28
watto700's Avatar
Now that you've got one you'll never need it but it looks like the right one! Well done
Cheers,
Jeff.
mayhem
Feb 6, 2024 07:26 AM
bjarnetv
May 18, 2023 08:46 PM
malc4d
Dec 4, 2022 11:55 AM
rhofatl
Apr 21, 2017 12:18 PM
SamOscarBrown
Jan 1, 2014 12:41 PM
