XJ XJ12 ( X305 ) 1995 - 1997
XJ12 differential gear set
Old Mar 6, 2019 | 11:32 PM
Duane's Avatar
Default XJ12 differential gear set
Hello, I need your help. I have a 1932 Plymouth coupe with a 1976 jag xj12 rearend. I am wanting to install a new ring and pinion. Something like a 373 or 392 or ?. I have checked the internet for a gear set with no luck. Can anyone help me. Thank you so much.
Old Mar 7, 2019 | 04:22 AM
Lady Penelope's Avatar
https://www.jaguarclassicparts.com/uk
Jaguar XJ12 series 2 ?
Old Mar 11, 2019 | 12:27 AM
Duane's Avatar
Default XJ12
I have a 1976 XJ12 rearend in my 32 Plymouth coupe. I see it has 3.22 gears. I just installed a 46rh Mopar four speed OD transmission in my coupe and want to upgrade me differential to 3.73 or maybe 4.09 gears. I cant find a gear set anywhere. I read one could use a Dana 44 jeep Cherokee gear set but need to upgrade the pinion flange. Any thoughts?
Old Mar 11, 2019 | 06:54 AM
Doug's Avatar
Yeah, Jaguar used a 3.77 or 4.09 ratio on some cars but those gear sets are hard to find. Dana 44 gears will probably be your best bet.
Re-post your question in the Series I-II-II section. "Icsamerica" will come along and help. He has gear swaps down to a science.
juha_teuvonnen
Nov 7, 2021 02:41 AM
Terry007
XJ XJ12 ( X305 )
20
Sep 22, 2021 02:39 AM
Ric in RVA
Apr 3, 2018 01:26 PM
plums
Apr 12, 2011 06:06 PM
