04 xjr cylinder 3 misfire detected
Old Sep 1, 2024 | 06:16 PM
tanios's Avatar
Default 04 xjr cylinder 3 misfire detected
Hi, I am trying to get at the ignition coils on the right side of the engine to get at cylinder 3 so I can switch the coil between cylinder one and cylinder 3 to see if the misfire will move to cylinder one, and Im afraid to break anything, can anyone with photos help me with instructions, part of the wiring harness needs to be removed also, I dont wanna pull on it and break it, I do have the repair manual , all it says is ":remove",it dont say how, thank you all!
Old Sep 2, 2024 | 11:04 AM
Rickkk's Avatar
Personally, I wouldn't switch the #1 & #3 coil packs. Just purchase a new coil pack for the #3 cylinder (NAPA will have it), and be done with it. In all probability, a defective coil pack is what you have at the #3 cylinder. Be thankful that you're not having a problem with the #1 cylinder as driving the car would then be quite problematic. With a defective #3 coil pack, the car can limp along for months. I mean, I've been there.
Old Sep 2, 2024 | 12:27 PM
Rickkk's Avatar
You will have to remove the top engine shroud and the side panel in order to access the #3 coil pack on the passenger side. The side panel just pulls off, and the rest would be self explanatory. Actually, there are no metallic bolts to remove (except for the one that secures the #3 coil pack in place). In addition, be sure to securely attach the electrical connector to the new #3 coil pack. The electrical connector "should" plug in somewhat easy, but I had to "carefully" use a pair of channel locks when I had done it. Oh, when facing the engine, the #3 coil pack will be the 2nd one down on your left. Good luck!
Old Sep 3, 2024 | 11:14 AM
clubairth1's Avatar
Community Influencer
With the time and age of your car don't be surprised if the clips for the coils break. They are plastic and that has been cooked for 20+ years now. So be gentle as you can here!
Old Sep 8, 2024 | 04:49 PM
tanios's Avatar
Thank you all!!
I finally removed the plastic cover today and removed cylinder 3 ignition coil, I have tested it with a multimeter and it rad 0 ohms on all 4 pins, so i was releived and ordered one from rock auto online, $34.00 and $5.99 shipping, I wanted Bosh but couldnt find one, the I ordered it listed copper windings which is good, anyway thank you for all the advises , I put them all together in my mind and it was very easy job. Thank you!!
98Jagxjr
Jan 23, 2023 12:23 AM
Clackavosticus
Sep 2, 2022 11:07 PM
eewhiz
Jun 15, 2021 05:55 AM
dennisw
Jan 25, 2013 06:23 AM
boliversmith
Jun 2, 2011 08:34 PM
