04 XJR RFV Suggestions
Old Apr 7, 2008 | 09:06 PM
kmschaer's Avatar
Default 04 XJR RFV Suggestions
I have an 04 XJR with approximately 40k miles on it. I love the car but have always been a bit annoyed with a speed specific vibration @ 60-65 mph. I understand that the XJ8 is pretty particular regarding wheel balance/ radial force variance. I had GoodYear Eagle F1s for a while which were pretty bad. I changed to Yokohama Advans which areaceptable but still exhibit some vibration. I still think however that an 80k car should ride without any vibration. I have balanced this set of tires twice in 15k miles. RFV ranges from 6 lbs to 16 lbs.
Questions
Is minor vibration on a 19" low profile tire normal and to be expected?
What is a reasonable RFV to shoot for when balancing/match mounting?
If acheivable, should a 6 lb RFV on all tires have any vibration?
What are other possible problems causing this?
Any thoughts appreciated.
KMSCHAER
peterg19
Feb 10, 2023 09:02 PM
Donzi
Oct 18, 2018 12:26 AM
Richxk8
Sep 16, 2015 10:57 AM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
adam699
Sep 12, 2015 05:32 PM
