06 Super V8 Tachometer issues
Old Sep 28, 2020 | 01:19 AM
870tacops's Avatar
Default 06 Super V8 Tachometer issues
Evening All. New member here, I have a 2006 Super V8 with 86k miles on the clock. Went for a drive today and noticed my tachometer is dead. I tried turning it off and started the car again and you can see the tack barely stuttering from rest to just below the 0 mark. I did check the battery and the earth/ground points by the headlights and all is good. I tried disconnecting the battery for 1 hr and after connecting the battery the tach came alive and showed idling rpm. Once I revved it a few times it moved just fine and then it dropped back down and stopped at its resting spot below the 0 mark. I noticed this time that I can hear a slight winding noise at the gauge when I rev, almost like a slight grinding when a plastic gear slips a tooth. Has anyone experienced this issue? I appreciate the time and help.
Old Sep 28, 2020 | 04:58 PM
meirion1's Avatar
This problem is not unknown and is probably due to wear in the plastic cogs in the mechanism
at the rear.
https://www.google.com/search?rlz=1C...sclient=psy-ab
Old Sep 28, 2020 | 07:24 PM
870tacops's Avatar
Thanks for the info, do you know how to remove the wood panel on the 2006 super v8. I got most of it popped but it got stuck around the navigation screen leather trim.
Old Sep 29, 2020 | 05:44 PM
meirion1's Avatar
Sorry I have never had to do it.
I suggest that you search using Google eg 'Jaguar x350 wood trim removal'
just done it for you!
https://www.google.com/search?q=Jagu...hrome&ie=UTF-8
Use google images too if need be.
Old Oct 2, 2020 | 07:03 PM
870tacops's Avatar
Louenigma
May 13, 2022 04:49 PM
RANGER1956
20
Aug 17, 2021 05:03 PM
princemarko
Nov 17, 2013 07:23 PM
Valenzo
20
Apr 19, 2012 04:48 PM
