100 watt h'lamp H7 bulbs
Old Jan 23, 2017 | 04:54 PM
meirion1's Avatar
Default 100 watt h'lamp H7 bulbs
Has anyone fitted 100 W bulbs?
According to the owner's manual both full beam
bulbs are on a 20 amp fuse and they should draw 17.6 amps total.
so they should be ok?
Then there is the exra heat with plastic lenses?
I really don't want to cause any damage.
Old Jan 23, 2017 | 05:09 PM
paydase's Avatar
I would avoid it.
Even though the total draw would be below the fuse capacity, there is a serious risk that the current may heat the wires and contacts as they are not designed to carry a current practically twice as much as spec.
I think however that there are high efficiency bulbs such as Philips Xtrem or Osram that provide a substantially better enlightment than the normal H bulbs with the same current. A good alternative IMO
Old Jan 23, 2017 | 10:40 PM
Don B's Avatar
I like the Sylvania Silverstar bulbs for their brighter, whiter light without overheating existing wiring or plastic lenses, but the downside is that they don't last as long as standard bulbs. I probably replace them every couple of years or sooner.
Cheers,
Don
Old Jan 24, 2017 | 06:41 AM
Box's Avatar
Box
I use these on mine. Great price. Same relative color temp as SilverStar. DOT approved.
https://www.amazon.com/Hella-H7-Halo...words=hella+h7
Old Jan 24, 2017 | 03:41 PM
meirion1's Avatar
Many thanks for the Amazon link-I don't usually use them because I
prefer not to use a credit card, however I will now.
I see they have Sylvania Star also-these are not available in OZ.
