2004 XJ8 Air suspension fault after I replaced all the expensive stuff - RESOLVED
#61
Received 12,737 Likes
So I have replaced both front air shocks with new Bilstein shocks. Car so far does not drop but we haven't had any single digit cold for a true test. Thought all was good until 3 days after replacing I got a code never seen before in addition to 2303. Got code C1429 and C1424. Open circuit.
You can download the Diagnostic Trouble Code Summaries at this link:
Jaguar X350 DTC Summaries
C1424 indicates an open circuit in the front left shock adaptive damping actuator, which could be as simple as the ECATS solenoid connector is loose or disconnected from the top of the air spring/damper unit you just installed.
The manual does not list C1429, but the code for the same problem at the front right shock is C1419 - could that be your other code?
Cheers,
Don
#63
MrWhite
31
03-25-2021 04:28 AM
LoveUnreliableOverpriced
05-21-2015 08:07 AM
kandaonly
11-03-2008 05:25 AM
