2004 XJ8 Engine Light on throwing P0829 code
Old Dec 30, 2023 | 12:00 PM
goldgun's Avatar
Default 2004 XJ8 Engine Light on throwing P0829 code
my Xj8 shifts a little rough,sometime i just get a gearbox fault light,this time i got the check engine light and the gearbox light at the same time,had it scaned and shows the P0829 code,any ideas
thanks
Albert
Old Dec 30, 2023 | 01:37 PM
meirion1's Avatar
https://www.google.com/search?q=p082...hrome&ie=UTF-8
Old Dec 30, 2023 | 03:31 PM
motorcarman's Avatar
DTC guide for you.
File Type: pdf
Old Dec 31, 2023 | 07:21 AM
Petz's Avatar
Auto transmission . ZF6HP26 ON ALL X350/358
OIL LEVEL fill plug screw left side on the transmission open should overflow a little dribble when oil at min 40 degrees centigade.
Next your rear reluctor rings or the wheel speed sensors hidden on the outside left and right just behind the brake discs. Can cause the same
Petz's Avatar
Oil woud normally be Zf lifeguard 6
Old Dec 31, 2023 | 07:30 AM
Petz's Avatar
Give in gearbox fault P0829 here in search
jancosteenkamp1
Jun 20, 2022 10:10 AM
Squider03
Mar 22, 2022 12:54 PM
pcox1
Jun 12, 2008 07:47 PM
