2004 XJ8 gear shift problems
Old Oct 1, 2018 | 12:38 PM
Teresa Joyner's Avatar
Default 2004 XJ8 gear shift problems
I own a 2004 XJ8 and the car won't drive when you put the car into reverse or drive. The issue came when the bolt came loose and now it won't move at all. We're not sure if the transmission is off. Can you please assist?
Old Oct 1, 2018 | 01:11 PM
S-Type Owner's Avatar
Welcome, Teresa. Your problem is, I believe, fairly common with the ZF automatic transmission that your car comes equipped with... There are two bolts that attach the cable linkage to the transmission housing; these small bolts can come loose and the car will not move from park into the forward or reverse gear ranges. What gear does your car show illuminated in the shift quadrant when you move the level from park? Or put another way, does "P" stay lit when you shift into "R" or "D"...?
Old Oct 1, 2018 | 02:59 PM
While my husband was tightening the screw it was illuminated in drive, but when he turned the bolt it moved the gear into park and it wouldn't shift. I turned the car off and it reset back to park and now it's back to gears functioning, but it still won't go in reverse or drive. He only turned one bolt.
Old Oct 1, 2018 | 06:16 PM
There are two small bolts, so he may have aligned the cable assembly into the wrong bolt hole. The electrical signal for the indicator quadrant comes from the transmission itself and not the linkage. I suspect something is misaligned.
JR
Soldierfc
Oct 8, 2016 05:53 PM
JagBenny
Oct 7, 2016 10:06 AM
Flora Maestas
Oct 3, 2016 07:40 AM
Don B
General Tech Help
Nov 9, 2015 12:59 PM
