2004 xj8 radiator removal
Old 11-27-2016, 05:48 PM
tomcoo's Avatar
Default 2004 xj8 radiator removal
2004 XJ8, can the radiator be removed without disconnecting the AC condenser line? I don't see how.
By the way I have read many posts on leak detection and did not see any suggestions for using UV leak detection die. Glows under UV light. I found it useful.
Old 11-27-2016, 09:47 PM
Received 1,420 Likes on 1,063 Posts
Hi, I don't believe so. You would have to evacuate the freon from AC system before disconnecting lines...
Old 12-04-2016, 03:18 PM
Lagonia's Avatar
I replaced the radiator on my XJR and the condenser line had to be disconnected. No way around it that I could figure out.
The following 2 users liked this post by Lagonia:
abonano (12-04-2016), Don B (12-04-2016)
