2004 xj8, reverse parking alarm not working
Old Oct 8, 2014 | 09:46 PM
SableCat's Avatar
Default 2004 xj8, reverse parking alarm not working
I recently had some work done on my xj8. When I got it back the reverse alarm didn't work. Is there somewhere I can check to see if perhaps they unplugged it? Perhaps an on/off switch? (I do not have the front sensors)
Tom
Old Oct 9, 2014 | 07:38 PM
Sean W's Avatar
Tom
Hi Tom. You might want to provide a bit more information. By not working, you mean you don't hear the multiple beeps, or you don't hear the long beep when putting in reverse (meaning system failure) or you hear nothing. If you hear nothing, I would check the speaker.
Old Oct 9, 2014 | 11:06 PM
abonano's Avatar
I addition to the speaker - I would check the fuse.
Old Oct 10, 2014 | 02:52 PM
Sean W's Avatar
Duh, my bad. Yes abonano, I agree. Always start with the power supply
Old Nov 27, 2014 | 01:28 AM
SableCat's Avatar
Thanks to all who replied. It turned out to be a bad speaker.
Tom
Old Feb 22, 2015 | 10:47 AM
rsmartin's Avatar
Tom
how did you determine it was the speaker? did you repair it yourself?
Old Feb 23, 2015 | 11:08 PM
Grio's Avatar
Was curious on that as well. My xjr has no noise that I'd expect to hear from the sensors and am suspecting that it is probably the module that is located in the trunk. I think someone had said to listen outside for some sort of noise or clicks in the back. I only have the rear parking assist. Already checked the fuse, don't know where the speaker is located, but will have to hunt around. I ordered a used module ( for my car) 2W93 15K866 AC and will see if that quick swap out works. Different connector...sort of a cam lock type that took a few minutes to figure out.
Old Feb 24, 2015 | 07:38 AM
rsmartin's Avatar
in my case, the system works. I was just curious if the poster would elaborate on how they troubleshooted to the bad speaker.
according to section 86.54.19 of the workshop manual, the speaker is under the parcel shelf. you have to remove the parcel shelf for access
supposedly while the car is in reverse gear you should hear clicking noises from the sensors.... unless you have a very long neck you'll need an assistant in the driver's seat while you listen for the sensors... haha
Old Feb 24, 2015 | 01:57 PM
SableCat's Avatar
I was told that the speaker was bad by an experienced Jaguar mechanic in my area. I did not watch him diagnose the problem as the car was in the shop overnight for a more serious problem...which he fixed.
I have wondered though, whether he really checked it out or just told me the usual answer. I am going to take it to another shop to get it fixed. I want that feature to work as it helps you keep from dinging your Jag. I want my cat to stay beautiful for a long time.
When it is fixed I will post about what was wrong.
Tom
Old Feb 24, 2015 | 03:03 PM
meirion1's Avatar
The weak links in this system are the sensors and sometimes the sounder.
I seem to remember that it is possible to check the operation of the sounder
using wiring at a rear light.
Need to check diagram for details.
I could never hear any sensors ticking but I do have a slight hearing
problem.
LOL
Old Jun 24, 2015 | 01:01 AM
SableCat's Avatar
The problem was diagnosed using a code reader. They had to remove both parts of the rear seat and the package deck to fix the speaker.
Tom
philwarner
Dec 6, 2021 07:13 AM
rsmartin
39
Nov 12, 2021 01:09 AM
johnnie ryall
Oct 19, 2015 09:44 PM
Will P
Aug 27, 2015 06:52 PM
Terencex
Aug 26, 2015 08:47 AM
