2004 XJ8 VDP - squeaking noise from steering wheel
Old Feb 11, 2011 | 06:49 PM
310jag's Avatar
Badda-bing! Problem solved.
Old Feb 11, 2011 | 08:39 PM
DB6's Avatar
DB6
ud
Default Re.. the $600 ring job posted 2 back
The common noise I think most of us get is def from the power pump and is affected by temp and fluid and lube , the Jag super lube bottle TSB fix appears to work sometimes.
Damn noise is annoying .
Old Feb 12, 2011 | 05:11 AM
Cadillac's Avatar
Cool beans, glad you fixed the problem
Old Feb 12, 2011 | 10:31 AM
amcdonal86's Avatar
Originally Posted by relinuca
FWIW, my technician said my steering wheel "squeak" was caused by wear on the various electrical compression rings within the steering wheel hub. Cost to replace = $600...requires pulling the wheel, etc., etc., etc., about 3+ hrs. labor + parts. I have chosen to live with the noise, which comes and goes depending on outside temperatures.
He also said don't even think about squirting some WD40 in there...that would cause untold problems.
(My '04 XJ8 has 170K miles.)
That wouldn't explain why it only happens when the engine is on (ps pump running)!
Old Feb 13, 2011 | 05:37 PM
DB6's Avatar
DB6
ud
Default Today
I have started sucking out and replacing the fluid with Mobil synth ATF as some others here have tried, I see the oem spec for P/Steering fluid is Dex 111, does any one think the Mobil ATF is a better fluid to have in it than the original Dex 111, I hope I dont screw it up by adding this.
Old Feb 13, 2011 | 05:41 PM
amcdonal86's Avatar
You're not sure? I added Lucas Oil Stop Squeak n' Leak based on your recommendation!!!!
Haha, by the way, it's hard to tell if it's worked. I did it yesterday but haven't had a chance to really drive it too much. It was still doing it this morning and it was about 50 degrees this morning (according to my car thermometer). However, it did seem to go away after I went for a short 15 minute drive. But it's pretended to go away before and come back with a vengeance before!
Old Feb 13, 2011 | 05:57 PM
DB6's Avatar
DB6
ud
Default I have found the answer
http://www.mobiloil.com/USA-English/...exron_III.aspx
so yeah it is ok to use.
Amac, I know it is frustrating, I think some pumps are whinier than others and some get fixed just by adding one bottle of the Jag fluid.
I added one bottle, did the install procedure and it def helped, but then came back but not as bad.
That's when I sucked out and added almost a full bottle of the Lucasoil, which helped to stop 75 % of the noise when the car is warm, but its still whiney on cold start up for 5 minutes then gets quieter.
I am guessing that on a sensitive whiney pump it is a question of getting the right amount of "superlube" in there, I think that in the cold the Lucasoil additive might be too thick;we will see.
If this dont work I might try sucking out and replacing the fluid then adding 2 of the Jag bottles.
Old Feb 13, 2011 | 06:00 PM
  #28
amcdonal86's Avatar
Is it really the pump? Or is it a seal in the steering rack?
Old Feb 13, 2011 | 06:06 PM
DB6's Avatar
DB6
ud
Default I have no idea
But its something down in The Abyss , and I don't want to go down there to find out.
Old Feb 13, 2011 | 06:26 PM
  #30
amcdonal86's Avatar
Oh well, I can live with it. I'll just have to trade the car in in the summer rather than the winter!
Old Feb 22, 2011 | 07:12 PM
  #31
amcdonal86's Avatar
Out of curiosity, do you notice some wobbling/vibration in the steering wheel when steering at low speeds when the car is warm? I wonder if it's just the pavement, or if there is something wrong with my PS system.
Old Mar 18, 2011 | 07:27 PM
  #32
amcdonal86's Avatar
Well, it's warm today and I noticed the car was doing it with moderate intensity again. No noise, but it feels almost like what a dipping/low idle feels like. However, the idle doesn't seem to be lowering to the point of causing vibrations/wobbling.
Has anyone else experienced this? It seems to only happen when the car is hot.
Old Mar 19, 2011 | 12:07 PM
  #33
DB6's Avatar
DB6
ud
Default Just do not put the additive in the wrong hole
I added one to the brake resevoir while I had head up ***; one expensive mistake!
It is very corrosive to rubber, master cyl alone is $600.-- just for the part.
Looks like that is as far as the damage goes but still will be into at least $1000.00 plus by the time it is flushed and flushed and bled after replacement.
Old Mar 19, 2011 | 05:09 PM
  #34
amcdonal86's Avatar
Oops! That stinks!
I am sure I didn't add it to the brake reservoir, though.
Old Apr 14, 2011 | 09:24 AM
  #35
amcdonal86's Avatar
Well, it seems to be pretty severe now. But it still only happens at certain times--at low speeds when maneuvering in the parking lot by turning the wheel at a moderate pace. Seems to happen the worst when I'm going in reverse.
Am I killing my power steering pump? I only added about 1 quart of that lucas oil stuff in, and that was done by removing the fluid in the reservoir, filling it with lucas oil, running the car a day, then repeating the process, so I figure I only have a 30-40% concentration of this lucas oil stop leak stuff, at most.
Old Apr 14, 2011 | 02:37 PM
  #36
DB6's Avatar
DB6
ud
Default The squeek goes on
I have added LubeGard power steering protectant, it is 4 ounces, thin and clear, for power steering noise, I got it from Napa, it seems to have queitened it down a lot in the last 2 days, will let you know after a few weeks.
Old Apr 14, 2011 | 04:04 PM
  #37
amcdonal86's Avatar
My god, how many things have you put in there now? The lucas oil stuff worked for me
Old Apr 14, 2011 | 05:01 PM
  #38
DB6's Avatar
DB6
ud
LOL !,
next is some chicken fat,a pigs ear and some mice brains !
That should make it nice n slick.
Seriously that Lubegard stuffappears to have done the trick, I have big ears and there is no noise whatsoever, just make sure that you do not put it in the brake resevoir.
Old May 19, 2013 | 01:04 AM
  #39
sweeper's Avatar
I am also experiencing the squeaking steering wheel, it's not the pump that makes the noise, according to the sb it is the pinion seal drying out? I have had the covers off and yes i think this could be the case, the noise is there even when engine switched off and with very small movements of the wheel, i tried to locate and it seemed to be coming from every where, quite how the additive works i don't know, but i'll give it a go and see what happens. (ps i did squirt some wd40 around the column, made no difference but crucially it did effect the dsc! but all is working ok again now.
Old May 19, 2013 | 08:37 AM
  #40
Frank M's Avatar
Last fall I got the additive from: sngbarratt.com
When I installed it I did not have much hope as the squeak had been going on for years.
Low and behold, it has been quiet as a church mouse since then..
