2004 XJR supercharger auxiliary water pump bracket
While replacing my radiator on my newly acquired 2004 XJR I noticed (amongst many things) that my auxiliary water pump for the supercharger was not plugged in and wire tied in such a way that is kinking a hose. Obviously someone not very skilled had their hands on this car. There is a list that I am currently having to fix. My question is, since mine is clearly missing does anyone have a source for the bracket that holds the aux water pump in place? Or an aftermarket solution?
Might have to buy the entire pump from a recycler to get it, and even then first make sure it even comes with it.
Do you have the resources to DIY a substitute?
Doubt it is worth a parts house attention to stock those as a non-wearing part, so long lead time if even they are still in the system at all?
I do. I did find this on Amazon that I think I can work with. https://www.amazon.com/External-Filt...kaAkZNEALw_wcB
PowdyrdWyg
19
Nov 2, 2023 11:09 AM
oldtvman
May 12, 2015 01:53 PM
roger.neill
Dec 22, 2013 08:39 AM
