Water pump install on 2004 s type r
Old May 12, 2015 | 12:48 PM
oldtvman's Avatar
Default Water pump install on 2004 s type r
Good afternoon,
Well I finally got the proper belt for the supercharger, but the water pump I received is two pieces, the front end of the water pump, gasket and then a thin cap or end that would go into the block. Trouble is if you install the water pump as is the pulley would stick out too far for the accessory belt. And taking the back portion off leaves you with a gasket that I'm not sure would seal properly.
Anybody had any experience with the s type r water pump replacement?
thanx
Old May 12, 2015 | 01:53 PM
JagV8's Avatar
Is it the right one?
stanjag
Dec 29, 2024 08:26 PM
Xj812
Oct 26, 2015 05:04 AM
celticpiping
Sep 18, 2015 06:17 PM
EastFalk
Aug 29, 2015 08:22 PM
Aegis21
Aug 27, 2015 08:30 AM
