2004 XJR suspension problem after repairs
Old Apr 19, 2012 | 03:42 PM
mdrag's Avatar
Question 2004 XJR suspension problem after repairs
I've unsuccessfully searched the forms for a similar problem.
I have a 2004 XJR with about 120k miles. Due to a leaking front shock, both front shocks were replaced with Arnott units. An air suspension fault continued to show up, and the repair shop diagnosed a faulty air compressor.
The air suspension fault code cleared after compressor replacement. However, I noticed the following day that the passenger side of the car - both front and rear - was significantly lower than the driver's side after sitting for 30 minutes or longer.
Opening a door would immediately cause the passenger side to raise to a normal level. No fault codes would appear when the vehicle was started.
The local repair shop diagnosed a leaking passenger side rear shock. Two new Arnott rear shocks were installed, however this did not fix the problem. They are suggesting a problem with a solenoid.
Does anyone have any ideas or suggestions on how to proceed?
Old Apr 20, 2012 | 04:01 AM
Fraser Mitchell's Avatar
There is a process to reprogram the ASM to react correctly to the height detectors, (two per rear, one per front, maybe two if an early car), following suspension work.
Paradigm
Jun 15, 2019 05:59 AM
Fraser Mitchell
Oct 1, 2015 04:06 AM
Donzi
Sep 7, 2015 12:06 PM
johanasu
Sep 3, 2015 12:39 PM
aquifer
Aug 29, 2015 04:54 PM
