2006 XJ8 having random freak-outs
Old Aug 16, 2012 | 09:34 AM
mattjs33's Avatar
Default 2006 XJ8 having random freak-outs
I'm having an issue these days with my '06 XJ8 --
Twice this has happened upon initial startup, twice while driving. What happens is every light on the instrument cluster lights up, all the gauges are dead, and every warning bell is dinging, and I get warnings in the message center of every fault the car could have. If I shut it off, it will restart, at least the first time or two. After a few more tries, it won't restart at all. Give it a minute or two, maybe open the trunk (I was going to see if I could disconnect the battery), and eventually it will restart. If I restart it enough times I will get all the lights and warnings to turn off, but then I'll still have the check engine light on.
After a few more drive cycles the check engine light will go off on its own. Scanning it in the meantime however will reveal a litany of errors. Basically what it tells me is that the body control computer has lost communication with the parking brake module, cruise control module, instrument panel, HVAC module, basically every module on the car that doesn't control the engine.
What is happening, and how do I fix this? Is it merely a connection issue on the BCM, and where would I look? Or does the car simply have demons, and I need to consult a priest?
Old Aug 16, 2012 | 12:01 PM
guy's Avatar
guy
This has happened to me only once. My preferred tech found that a few of the 'modules' in the trunk had been knocked loose. We think by the unsecured spare tire.
Old Aug 16, 2012 | 12:33 PM
mattjs33's Avatar
Where are all of these modules located?
Old Aug 16, 2012 | 12:54 PM
guy's Avatar
guy
In the trunk, under the floor, across the back of the car, beside the spare tire.
Old Aug 17, 2012 | 12:20 PM
timfountain's Avatar
I saw this issue on my '04 XJ8 and it turned out to be a bad battery.
Old Aug 19, 2012 | 07:57 PM
androulakis's Avatar
What he said. Low voltage wreaks havoc on our Jags.
Replace the battery (especially if it is original), and all should be well.
Take care,
George
Old Aug 22, 2012 | 10:08 AM
mattjs33's Avatar
Battery is pretty new, I replaced it shortly after I got the car last March.
It happened to me again last Thursday. Upon startup I had all the warning lights on, and the parkbrake failure warning and chime. This time I got out and went into the trunk. I kind of fiddled with the connections to the modules in there, as mentioned above; just kind of made sure they were tight. Started it back up and not only were the warnings gone but this time the check engine light was out immediately. Even better, it's been incident-free since. Knocking on wood that the demons have been excised.
Old Aug 24, 2012 | 09:58 PM
guy's Avatar
guy
glad it worked out for you.
Mugatu
22
Jun 23, 2020 01:50 PM
bdboyle
Sep 16, 2019 05:58 PM
magmedia
Aug 15, 2019 08:54 PM
SCMike
Sep 9, 2015 09:30 AM
hen555
Sep 7, 2015 11:13 PM
